0 members (), 191 guests, and 2 robots.
Topics128,089
Posts1,056,141
Members48,436
#91252 12/18/2002 5:04 PM
I got a 6v starter with the original foot pedal trigger for my 270. The truck has been modified prior to me owning it with a 12v system. I have been told that I can run the 6v starter off the 12v system without too much worry.
I need to get the proper ignition coil to go with this new starter and I am not sure if it matters if I get a 6v or 12v. Can anyone help me with this?
Thanks in advance.
Tom
Whats down in the well comes up in the bucket, so watch who's KoolAid you drink.
#91253 12/18/2002 6:31 PM
Your starter will be fine, it will just start the engine faster than it would with 6v. You definately want a 12v coil and a ballast resistor to protect the points.
There's a good overview of the conversion here . I went with a single wire alternator and replaced the entire wiring harness; quicker starts, brighter headlights, electric wipers all make the truck more user-friendly.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#91254 01/03/2003 4:20 AM
Bluebird,
Get a 12v AC Delco 1 #12337166 coil not internally resisted. I did my conversion 8-9 months ago and boy, what a difference. Yes my original foot starter has never responded so fast before : - )
Craig
