6 members (Bill Hanlon, 3B, DadsFirstPickup, 1955 1 Series, Jon G, Joe H), 101 guests, and 3 robots.
Topics128,078
Posts1,056,046
Members48,433
#912424 01/17/2013 9:14 AM
What are you guys using as a battery disconnect switch on your 6v systems?
I want something a little quicker than a wrench to remove the terminal from the battery lug. smile
I use the disconnect which attaches to one battery terminal and the battery cable. It has a big green knob that turns to disconnect. The green isn't important but the nice size gives you leverage. I also use one to disconnect my camper battery. I think I bought them at Walmart.
I saw those, Battery Doctor makes them. Didn't know if they'd hit the compartment lid tho.
I also found these...
https://www.autozone.com/autozone/a...vers/_/N-25hn?itemIdentifier=422528_0_0_
Might just get them and the premade 1ga cloth covered cable from Jim Carter and call it a day. No cutting, no soldering and no extra junctions.
^ Didn't like the fact that I had to enter a ton of info before I could get a price on the Cole Hersee site.
Ended up getting a nice heavy duty switch recommended to me by Hotrod Lincoln. ...looks like the locking handle Flaming River branded 'Big Switch' and mounting bracket.
Yeah. That's why I get a Cole Hersee part number and shop elsewhere.
^ Good call.
Those heavy duty CH disconnects are avalable from a lot of
different vendors. I think I got one from a FLAPS a few years
ago. Cole Hersee is an OEM company and you have to get them
from one of their distributors. They are quite expensive
compaired to the ones that are used at the battery. About $35
back then if I recall correctly. I haven't installed it because
bought it so I could hide it and I haven't figured out exactly
where I want to put it. Also to hide it I would need to get two
more longer battery cables, so there it sits in a box somewhere
in the barn.
DG
Denny G
Sandwich, IL
On my '49, I think I had it on the side of the battery box. Or maybe it was on the frame inside the fender well. I also had some jumper studs on the frame. I had redone the floor ( before panels were sold at vendors ) and it was solid sheet. So the only way to service the battery was to drop it down. I had the key version for the shutoff switch as a theft deterrent.
I just installed a knife switch to disconnect battery on my '41 GMC - purchased from NAPA.
knife switch battery disconnect
1960 GMC 1/2-ton Fleetside
"Donald"
More pix on Flickr
1941 GMC 1/2-Ton Short Box Stepside
"Wilburforce"
More pix on Flickr
1943? Chevrolet G7107
1946 Dodge COE 1-1/2 ton
1939 Allis Chalmers model "C"
