4 members (Bill Hanlon, TooMany2count, 55shaker, Gdads51), 109 guests, and 2 robots.
Topics128,076
Posts1,056,280
Members48,441
I need the following original specs for a '51 3100 6v positive battery cable...
- Lug Hole Diameter (both ends)
- Cable Length
Ideally I'd like to find a premade 1ga (or 1/0 or 2/0) cable. Everyone from NAPA to the usual online vendors only list a 4ga positive cable for AD trucks. ...I believe 2ga was original.
Check Tractor Supply Company
Never mind. Found one on Jim Carter's site...
1 gauge
39 3/4"
Cloth covered
http://www.oldchevytrucks.com/cart/product.asp?prodid=EL164&i=|battery%20cable|||51?sdes=battery%20cable|
...they also sell a vinyl covered 2ga version.
I was going that route but I didn't know the lug hole diameter at both ends or the correct cable length.
The 1ga cable from Carter's should be sufficient and I know it'll fit.
I was able to pick up some 0ga cables from JC whitney a couple years back. Very stout and top quality!
Ed
Forty9, what were the lug and terminal hole diameters?
hey Eric, you want terminals to fit the battery and starter you have rather than someone elses wink
These are 2/0ga cables, one end was battery terminal and other lug had a 1/2" hole. I used a copper washer like the kind used on oil drain plugs (only smaller..think I got it at Ace hardware) to act as a reducer on the starter stud (foot starter). My neg cable goes to the starter lower mounting bolt and was a perfect fit.
Ed
Wah waahhh. grin
Cool. The closest tractor/farm supply store is about 45min to 1hr away. I think I'm just going to call up a stereo store that does automotive installs and see what they have. Finding terminals to fit shouldn't be too tough.
Check welding supply or businesses that service large trucks.
Ed
