| | | Forums66 Topics128,100 Posts1,056,168 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | I need the following original specs for a '51 3100 6v positive battery cable...
- Lug Hole Diameter (both ends) - Cable Length
Ideally I'd like to find a premade 1ga (or 1/0 or 2/0) cable. Everyone from NAPA to the usual online vendors only list a 4ga positive cable for AD trucks. ...I believe 2ga was original. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Check Tractor Supply Company
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Never mind. Found one on Jim Carter's site...
1 gauge 39 3/4" Cloth covered
http://www.oldchevytrucks.com/cart/product.asp?prodid=EL164&i=|battery%20cable|||51?sdes=battery%20cable|
...they also sell a vinyl covered 2ga version. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Check Tractor Supply Company I was going that route but I didn't know the lug hole diameter at both ends or the correct cable length. The 1ga cable from Carter's should be sufficient and I know it'll fit. | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | I was able to pick up some 0ga cables from JC whitney a couple years back. Very stout and top quality!
Ed
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Forty9, what were the lug and terminal hole diameters? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | hey Eric, you want terminals to fit the battery and starter you have rather than someone elses  Bill | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | These are 2/0ga cables, one end was battery terminal and other lug had a 1/2" hole. I used a copper washer like the kind used on oil drain plugs (only smaller..think I got it at Ace hardware) to act as a reducer on the starter stud (foot starter). My neg cable goes to the starter lower mounting bolt and was a perfect fit.
Ed
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | hey Eric, you want terminals to fit the battery and starter you have rather than someone elses  Bill Wah waahhh. These are 2/0ga cables, one end was battery terminal and other lug had a 1/2" hole. I used a copper washer like the kind used on oil drain plugs (only smaller..think I got it at Ace hardware) to act as a reducer on the starter stud (foot starter). My neg cable goes to the starter lower mounting bolt and was a perfect fit. Cool. The closest tractor/farm supply store is about 45min to 1hr away. I think I'm just going to call up a stereo store that does automotive installs and see what they have. Finding terminals to fit shouldn't be too tough. | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Check welding supply or businesses that service large trucks.
Ed
