| | | Forums66 Topics128,094 Posts1,056,051 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | I bought the u-joint gasket set from classicparts.com : www.classicparts.com/1935-54-U-Joint-Ball-Gasket-Seals/productinfo/92-111/#.UPHDt2_efU8 to replace the ball joint collar oil seal(cork) that seems to be leaking. Now I'm having trouble getting the U-joint collar off of the torque tube. Do I need to remove the cross member just below to drop the torque tube down far enough to slide the U-joint collar off? Thanks | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | Thanks Dads50! Got the cross member off now and ready to install the new gaskets. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Adjustment procedure ...link... My test ...link... When I did mine last year the leak did not completely stop. | | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | Where do I get universal ball collar shims? Also, what can I use instead of graphite grease for the new cork oil seal? Thanks | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | The shims came in the kit they are the 4 blue paper gaskets. I ended up using only one ...pic... I would think any general purpose grease will work. I just use a bit of oil on the seal. ...pic... | | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | Thanks for the info Dads50. I wish these gasket kits came with instructions and/or diagrams labeling what was included. What are the black paper ones for? I gotta inspect the yoke and u-joint since one of the bolts was loose inside of the ball collar. Hopefully it didn't damage anything in there. Thanks again | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Might the other 6 bolt-holes gaskets in the u-joint kit be for use with the 3/4 ton extension cover?
| | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | Another question: On the narrow end of the ball joint collar, I'm replacing the gasket that butts up against a metal washer. I noticed in your Pics(DADS50) that your ball collar has 2 metal washers. Is my truck missing one? Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Two metal washers sandwiching the seal.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | the repair kit is universal, covers 1935-56. The black gaskets might be for the earlier trucks or as Tim suggested a rear cover. the manual shows 2 steel washers ...link... Fig 76... I dont thik the washers are reproduced. if your missing one try posting an ad in the parts wanted section of the forum, or have a machinist make one for you. I was lucky enough to have a fellow stovebolter help me out with washers and advise when I replaced my ball seals last year. | | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | Update: After responding to a local Craigslist ad about a motor, the seller had a torque tube they were getting rid of and gave me the washers for free! Timing is everything. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The gaskets/shims with 6 holes are for 1950-54 Power Glide transmissions.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks, Dave,
I think you have posted that before, when this topic arose. Some of us are a little slow and forgetful.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I think I'm in the same club.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | While I have the u-joint out of the truck, I can feel a small amount of play between the u-joint trunnion and bearings/bushings. Is this a sign that I need new u-joint and bushings? Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Thanks for this. I need to advertise for the two washers.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | When doing this project do you guys have a recommendation for the location of the jack stands for the rear? Under the frame or under the rear end housing? | | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | Dads50, Thanks for posting your video on the adjustment of the ball collar shims. After getting the new u-joint installed and putting everything back together with new gaskets, the ball collar sleeve now leaks from the end of the sleeve and where it bolts to the transmission. Is there any chance of stopping this leak or is this just common? Could I put some permatex or something on it to seal it? Thanks | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Luckily my leak at the ball stopped after installing the new cork seal and one shim.
But my leak at the threaded ring didn't stop after the repair.
Maybe someone else an chime in with an idea for you. | | |
