2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#91134 04/28/2003 9:27 PM | Joined: Jan 2001 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2001 Posts: 142 | I got my new harness from Chevy Duty last Friday. And I wonder if any of you guys would be willing to help me with some questions via email. My truck is a '51 GMC with an alternator. I have never done anything like this before. I have made a "as is drawing" but I do have a few questions. Thanks in advance! | | |
#91135 04/28/2003 10:04 PM | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | I have a single-wire 90A alternator and a Chevy Duty harness. Feel free to shoot an email my way. | | |
#91136 04/29/2003 1:31 AM | Joined: Aug 2001 Posts: 20 Junior Member | | Junior Member Joined: Aug 2001 Posts: 20 | i put in a chevy duty harness, my only problem was with the alternator. My alternator has an external regulator, the harness was for an internal. But through trial and error I think I got it hooked up right, 2 weeks of driving with no dead battery. Feel free to ask away.
54 1ton
#91137 04/30/2003 1:21 AM | Joined: Aug 2001 Posts: 20 Junior Member | | Junior Member Joined: Aug 2001 Posts: 20 | are you converting or has your truck already been converted to 12 volt? That would be the only reason that I know of to need the separate starter switch.
About the wire from the ignition to the alternator without continuity? this may be a stupid question but did you have the key on when testing, and also try it off. It may be that the screw terminals on the ignition switch don't match what you thought. Like I said my alternator wiring was all messed up because of the external regulator so I am not sure what should go where.
David
P.S. being a fellow woodworker have you given any thought to wooding up your truck. I know a lot of the purists will be upset, but I am making wood panels for the doors to replace the cardboard ones, also I think I will try wood sunvisors. I think this will all compliment the wood bed. Just my thought.
54 1ton
