| | | Forums66 Topics128,049 Posts1,055,695 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 85 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 85 | I have a 52 Chevy truck with a 216 motor - that often is hard to start when it's cold & has set for a while. The engine has been rebuilt, as well as the carb & it has a new fuel pump. What I suspect is the fuel doesn't get to the card before the battery gets low. Question: would a leaking intake manifold gasket impact how quickly gas can can be pushed/pulled to the carb? Also, I've found something called "Intake manifold aligning sleeves" which is a set of 3 rings that go between the manifold and the head; do these help prevent air leaks? Thanks. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | All the rings do is locate the manifold when you are putting it together. Do you have the choke connected on your truck? | | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | Try spraying carb cleaner at intake joint at head, carb base. A change in idle speed will tell if you have a leak. | | | | | Joined: Apr 2011 Posts: 85 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 85 | Yes, the choke is hooked up, but I will check to see that it is adjusted properly.. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | do these help prevent air leaks? Thanks. They do not help prevent leaks but they can cause a leak. one example is if you have your manifold decked or machined, the rings may also need to be dressed down as they may then be to thick. I purchased some step rings that were to thick delivered. | | | | | Joined: Apr 2011 Posts: 85 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 85 | Thanks gentlemen for your help. Checked the choke and sure enough it wasn't closing all the way. Made the adjustment & the engine started right up. I used the starting liquid and no increase in rpm. Also, good to know about the sleeves. Bob | | |
