2 members (JoeDude, carbking),
95
Mod | | | Forums66 Topics128,198 Posts1,057,268 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#91079 11/21/2002 10:17 PM | Joined: Sep 2001 Posts: 100 Member | | Member Joined: Sep 2001 Posts: 100 | Here's a simple (maybe simple minded) question.
The catalogs I took a quick look at don't list wire grommets for the park-light buckets on 47-53 GMC 1/2 tons. Will one of the standard firewall grommets work? And what about the park-light lens gaskets? Jim Carter has the bezel to fender gaskets.
Never start vast projects with half vast ideas.
#91080 11/22/2002 1:38 AM | Joined: May 2000 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: May 2000 Posts: 69 | Both grommets and gaskets are available from Chevys of the '40s. www.chevsofthe40s.com or call 800-999-chev | | |
#91081 11/22/2002 5:35 PM | Joined: Jun 2002 Posts: 19 Member | | Member Joined: Jun 2002 Posts: 19 | Believe it or not - I recently did this and also changed the socket to take the dual filament bulb. A couple days before, the wife bought a ceiling fan and after the installation was done, I had a couple extra grommets for mounting the fan blades - perfect fit!! Darwin
If you think you can or if you think you can't, either way you're right.
#91082 11/22/2002 5:36 PM | Joined: Jun 2002 Posts: 19 Member | | Member Joined: Jun 2002 Posts: 19 | BTW - Got my lens gaskets from Chevy Duty. Darwin
#91083 11/22/2002 10:48 PM | Joined: Sep 2001 Posts: 100 Member | | Member Joined: Sep 2001 Posts: 100 | Great. I see I was looking at the wrong catalogs. I also think I'll take your advice and look around for close fits before sending in more money.
Don't know how I got this posted twice. Maybe shouldn't have gazed at it afterwards.
Thanks again.
#91084 11/28/2002 7:45 PM | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | I'm also looking for the grommets that the wires go through for the parking lamp housing. My 1953 GMC has very hard grommets and I need to replace the wires and grommets. :confused: | | |
#91085 11/29/2002 7:27 AM | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | http://www.chevyduty.com I ordered the "firewall grommet kit" and had a couple left over, since I don't need a vacuum hose running to the wipers anymore. They also sell everything individually. | | |
