| | | Forums66 Topics128,031 Posts1,055,435 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Anyone know where to find the two small grommets that the speedo head to back case mounting screws go through? Detail - http://farm9.staticflickr.com/8086/8367191363_e34d09190e_c.jpgMine are all rotted and the head and face bounce around pretty freely. | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | I would look at a Ace hardware for a grommet of the right size and then reuse the old metal insert.
Ed
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | I did. Didn't find anything the right size and Ace by me has everything. I assume they have to be rubber to isolate the speedo head for some reason ... electric or just vibration damping?
If they just dampen vibration, I could use flat rubber washers. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | I did. Didn't find anything the right size and Ace by me has everything. I assume they have to be rubber to isolate the speedo head for some reason ... electric or just vibration damping? If they just dampen vibration, I could use flat rubber washers. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I used small neo-washers too. I have thousands of them for my work, come on metal roofing screws. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | So you just used four neo-washers and everything is fine?
I assumed they just isolate the speedo head from vibration but with everything grounding thru everything else and into the dash I want to be sure. | | | | | Joined: Feb 2000 Posts: 5,195 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,195 | They probably just insulated the head from case for noise. The cable is a direct link to the drive train so you will get vibration clear up to the dash. An rubber material should work.
Joe | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | BLUEMEANIE I bought grommets for my speedo housing at an electronics surplus/salvage store near me in Winter Park. (Greatest place in the world to find obscure parts and stuff that you didn't know you needed!) I'm sure that I bought extra, but the parts bin is MIA in my shop. > Grommets and speedo housing> Grommets closeupLooks like the grommets isolate the speedo head from vibration. A rubber washer without the rubber part that goes inside the hole in the housing would not keep the bolt shaft from vibratiing against the housing and head. Don't lose the metal insert while you are looking for a grommet. I lost one. Luckily, I had a couple of extra ones. Anybody know of a substitute for the insert? By the way, my '54 speedo and gauge housings were painted turquoise with green stripes. The inside of the inner bezels were painted turquoise and flat black. Don't know about earlier housings. > Photobucket gauge album. There are two sets of housings in the album. One is original inside. The other was painted silver by a previous owner. The back of the speedo was turquoise and cream.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Not exactly on topic, but after I got everything back together, the little round coloured plastic lens for the dimmer switch fell to the bottom of the gauge housing. I don't feel like taking all that apart again. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Paint the indicator bulb with a light spray of red paint or fingernail polish. The paint may burn off if you use the high beams a lot. If it does, remove and repaint.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Pepboys and other auto parts stores sell gel caps for dash bulbs. I'm using one similar to this for my high beam indicator - http://www.pepboys.com/product/details/9210570/ | | |
