0 members (), 85 guests, and 1 robot.
Topics128,049
Posts1,055,740
#907765 12/31/2012 5:55 PM
My wife coined up and purchased a Delta bench grinder as a Christmas gift. Anyhow, it seems to be built very good, regardless of where it is now manufactured. My only dissappointment is that one of the grinding wheels doesn't run true. It wobbles back and forth as though it's loose. I swapped the wheels side to side and even put an old grinding wheel on. It seems as though it's the "new" grinding wheel.
So, here is my question. How true should a grinding wheel run?
Chris
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Should run true with no wabble. Even if the center hole was not
bored perfectly perpendicular to the sides the large support
washer should hold it true against the flange on the shaft. The
only thing that could run out that could be trued up is the
O.D. which you can and should dress true anyway.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
There isn't any problem with the RH side wheel, so I swapped sides and it runs true on both sides. I'm thinking maybe the center hole may not be drilled straight or it's just a junk wheel. I'm planning on swapping it out for a wire wheel anyhow, so it's no big deal.
"The Fake Truck"
I also got a new bench grinder for Christmas (Porter Cable) with the variable speed feature and it's very nice. Only problem seems to be in finding good steel wire brush wheels. All I find are either brass or twisted wire which I don't want. So if anyone knows where to find decent (not cheapo Chinese crap) wire wheels I like to hear about it.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Check here, I've bought from them after reading great things on other forums. They really do have good products at fantastic prices.
http://www.lehighvalleyabrasives.com/servlet/StoreFront
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
McMaster Carr. They've got about any brush you will ever need
for your bench grinder. They will deal with the retail public
as well as the commercial customers and their delevery is fast
also.
http://www.mcmaster.com/#wire-wheels/=kzlcj2
Stay away from the hardware stores or places like Harbor Freight.
Denny Graham
Sanwich, IL
Denny G
Sandwich, IL
Originally Posted by Anonymous
Thanks Denny, I was able to find the one I have been looking for.
Say what? Somethings fishy here.
Give me ambiguity
or give me something else
Red dot, center of chest ...
Yeah, I know, I'm working on it.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
baldeagle....are you OK?
Dave
Yeah, why?
Paul Schmehl CI 6
geek@stovebolt.com
I guess I'm lucky, I'm within 10 minutes of a Grainger and a Fastenaal store. Sadly, most of the grinding stuff is Chinese made, but there's some US and Canadian suppliers in there too.
"Happiness equals reality minus expectations" - Tom Magliozzi
Moderated by  MNSmith
