1 members (TUTS 59),
95
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,624 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#90979 07/25/2003 7:30 PM | Joined: Dec 2002 Posts: 29 Member | | Member Joined: Dec 2002 Posts: 29 | The electrical system in my 2-ton flatbed is shot, and needs replacing. I am looking at getting the wiring harness kit from Chevy Duty, but I'm not sure if it will be the right size, that is, if it will reach all the lights. If this doesn't work, I don't want to have to spend $100 finding out. Is there a good aftermarket harness that might work? If nothing else, I will resort to replacing one wire at a time, but I don't want to have to do that. Any help would be appreciated.
'48 Chevy 2 ton Flatbed (daily driver) '70 BMW 2002 My truck is older than my parents!
#90980 07/25/2003 9:02 PM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | don't see why it would be much different, Teen - the back lights will need extensions to make the length, but that's easy, and all else should be the same
Bill | | |
#90981 07/25/2003 9:15 PM | Joined: Dec 2002 Posts: 29 Member | | Member Joined: Dec 2002 Posts: 29 | That's what I figured. I think I'll give it a try, and modify it if I need to. Thanks.
#90982 07/26/2003 3:10 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I bought the Chevy Duty kit for my '53 6500 and enough bulk trailer wire to run to the rear. I'm using the white wire for the brake lights and the yellow, green and brown as usual. I haven't gotten it all hooked up yet but I imagine I'll need a ground strap from the rear of the frame to the dump bed where the lights are if it doesn't already have one.(haven't been under that end yet) I don't know if the hinge point will make a ground. | | |
#90983 07/26/2003 3:38 AM | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | I don't know how long your truck is, but I had wire left over from the Chevy Duty kit on my 19.5' panel, and I had to route the wires up into the body to reach the taillight pods. If the wires are too short, it won't be by much. | | |
#90984 07/27/2003 5:54 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | My '53 2-ton 6500 has 179" wheelbase and a 16' bed. After looking at my shop manual I find the '48 2-ton was only offered in 137" (6100) or 161" (6400). But the point is, the harness will work. | | |
#90985 08/05/2003 6:59 AM | Joined: Dec 2002 Posts: 29 Member | | Member Joined: Dec 2002 Posts: 29 | I have the 6400 and it does have the 161" wheelbase. I went ahead and bought the harness, which comes itself with extra wire for "accessories" that I may end up using. OlBlue is out of town, and I think I'll need his help, so it may be a few days before I start redoing the wiring. From the looks of the harness it appears quite generous. I'll let you guys know how it goes.
#90986 08/05/2003 3:21 PM | Joined: Jan 2001 Posts: 332 Big Bolt Shop Curmudgeon | | Big Bolt Shop Curmudgeon Joined: Jan 2001 Posts: 332 | When in doubt, add a ground wire.
I'll double-dog guarantee you that there is enough paint, rust and grease on your dump bed to interfere with grounding tail lights, marker lights or whatever.
Drivin' down a 2 lane country road in a stovebolt.....cowboy, it don't get no better than this!
1946 1-1/2 ton Chevy "Ol Blue", or "THE BIG 'UN"
#90987 08/19/2003 5:29 AM | Joined: Dec 2002 Posts: 29 Member | | Member Joined: Dec 2002 Posts: 29 | Just for those that are interested, it fit, although we had to use the extra wire that came with the kit, and we had to pull wire from another harness to wire up the turnsignals under the dash. I assume the extra lengths of wire were for that. Still need to do a little troubleshooting, but it seems to be working great.
#90988 08/19/2003 6:38 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Great to hear it. Mine's still on hold mainly due to the heat. | | |
