1 members (2-Ton), 150 guests, and 0 robots.
Topics128,110
Posts1,056,241
Members48,437
Just replaced my sending unit. Gauge still didn't work. I got it to work, sort of, by grounding the sending unit mounting plate. Now on a full tank, the gauge reads 7/8 full. The gauges were new about 10 years ago. Any idea how I can fix this?
Junior Member
Junior Member
I just bought a 72 p/u and my gas gauge was not moving. I just ordered a new gauge cause the old one was very stiff and didn't want to move. I hope that fixes my problem. I wonder if you could adjust the float in the gas tank to correct your reading. Of course you would have to check the empty position also.
I don't know if this is against the rules or not. This guy will tell you everything you never wanted to know about trouble shooting you gas gauge woes.
http://www.chevytrucks.org/tech/gasgauge.htm
'67 GMC 3/4 292 4spd
Junior Member
Junior Member
Thanks Richard! Thats exactly what I needed.
