| | | Forums66 Topics128,068 Posts1,055,880 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 126 | I bought some of the generic insulation/sound deadener from LMC truck, its the stuff with a heavy foil backing and a felt pad on the other side. I'm hoping to quiet down the cab a little, after I put it all back together its still bare steel, a little noisy on the highway!
Anyway, I'm not sure which side goes against the metal. Foil side or felt side? Anybody know?
Da Viking | | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | | | | | | Joined: Jan 2010 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 126 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Felt will absorb and hold moisture. Be sure the metal is well sealed.
| | | | | Joined: Mar 2005 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 31 | I used heat shield & sound deadener brand part #25070 on my panel. The instructions say installing in engine compartment & floor boards aluminum foil is always towards heat. | | |
