| | | Forums66 Topics128,043 Posts1,055,612 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 132 | I'm getting ready to install my door panels. I was wondering if anyone had an idea of what kind of rubber molding I could use, so I don't have metal to metal contact.
thanks Brett | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Some 3M double sided tape might work but the stuff I have laying in the drawer seems like it'd be too thick. Maybe it comes in thinner sizes? 3M strip caulking is a putty type substance that can be used and might work. I'm interested in what others might suggest.
| | | | | Joined: Apr 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 132 | I haven't found anything that would work.I am thinkin about taking some clear tubing and slicing it. Just wish I could find a product made for this. We use something similar for electrical panels. We cut and run wire thru, but it is to wide and would show. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I was thinking of maybe tool dip... tape off your piece and brush some on possibly? If they are epoxy primed I'd think that's good enough. No?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I was thinking of maybe tool dip... tape off your piece and brush some on possibly? If they are epoxy primed I'd think that's good enough. No? excellent stuff for a lot of uses Bill | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I was thinking of maybe tool dip. Tool dip sounds like a better idea than what I suggested. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | By the way Lugnutz welcome to that other place you just joined!
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I've been laughing at myself since I posted that idea cause I had someplace in mind for it but couldn't recall what or where for the life of me... finally it just dawned, the edge of the heat diverter inside my heater box. It kind of needs to rub against the side to maintain some friction to stay in a middle postition but the scrapping sound just seemed off. so that's when I thought of that stuff. Like Red say's...
