3 members (Gray_Ghost, Otto Skorzeny, Stovebolt48), 29 guests, and 2 robots.
Topics128,023
Posts1,055,370
Members48,420
#908865 01/05/2013 1:17 PM
Does a hand engine starter (push button) connected to the battery and the starter work with a stomp starter like the one on my 56 Cameo 235 (to do compression tests). Would work better than the not-so-interested, less than enthusiastic help I would have to guide through it, if it will work. $17 at Flaps. .
cameo1956 #908886 01/05/2013 2:51 PM
no it won't, that's for a solenoid type starter - you need to use a lever like a large screwdriver under the hood, between the floor and the button, to activate the starter - it is possible to do it alone
Flxible #908891 01/05/2013 3:33 PM
Yup -- as I thought -- but thanks for the screwdriver idea, would have never thought of that. Thanks, Dale
cameo1956 #909660 01/07/2013 11:30 PM
Just be careful and make sure it's out of gear. Wouldn't want to hear anyone ran themselves over.
1939 Chevy 1/2-Ton Pickup Truck
More pix on Photobucket
1946 1.5-Ton Chevrolet Stake Bed
1940 Chevy Sedan - Frame-off Restoration
