1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 789 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 789 | Strictly for added safety, I am considering adding a 3rd brake light to my '48 Chevy 1/2 ton p.u.'s 6V electrical system. I really do not want to take away from the stock look of the truck. I envision using an l.e.d. strip and am looking for any recommendations on pursuing this project. Has anyone done this with their truck? Thoughts on the following:
1) placement of light 2) wiring run 3) vendor 4) price
Photos of one installed on a A.D. truck would be appreciated.
Thank you.
LUKE | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I put one on my 70. I got a strip light from J.C. Whitney. It is a LED. I dont know about the 6 volt thing though. It is stick on so I only had to drill 1 small hole for the wire. I tried to fish a wire to the instument panel but couldn't do it. It might be easier on your AD. I used one of the wires to the dome light & hooked the dome light to a toggle switch. I hooked the brake light wire to the wire off the stop light switch at the turn switch junction & used a low amp. fuse in it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I picked up a STOP light on ebay a few years ago and rigged it last summer to work on my '38 coupe. I made a stand for it to place on my package shelf. My '38 has a single tail/stop light so I guess it's my "second" brake light.  The harness I bought was set up for two tail/stop lights so I just ran a wire from the RH brake light circuit to the STOP light and put a high output bulb in it. Although they're getting a bit pricy any more I see STOP lights on ebay all the time.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I've seen this site suggested ...link... 6 or 12 volt Held on with cups so you can remove at shows and use while driving. | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | this is where my third brake light is: 3rd brake light it was placed in the stakes i bought from a fellow 'bolter and i wired it to the brake light switch directly so it would be unaffected by the directional signals.. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Jun 2009 Posts: 789 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 789 | These different ideas are appreciated. I need to sort through my options before the new driving season sets in next Spring  Merry Christmas to all! | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Happy new year, Luke! This is the one I'm planning on using. It's a c.1920s Protex Lamp. I need to paint the inset part of the lens and I'm still not sure where I'm gonna mount it. http://rustyfiftyone.com/2012/02/23/fun-stuff-pt-trois/ | | | | | Joined: Jun 2009 Posts: 789 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 789 | Is anyone out there using the "Brakelighter" as posted by DADS50? Just wondering about your satisfaction and the installation. Thanks.
LUKE | | | | | Joined: Jan 2001 Posts: 1,422 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,422 | I think the led strips look way out of place on an old truck, but that's just one opinion, here's mine. That was daylight in a darkened garage, at night it really pops. Regards, Cosmo
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Jun 2009 Posts: 789 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 789 | Can you share a close-up picture in the daylight of what you are using, along with how you have it mounted? Thanks. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Luke, I know you're trying to stick to original stuff but since you're considering a third brake lamp for safety reasons this might also be of interest. ...I assume you are using glass lenses on your tail lights... you might consider switching to the 21cp bulbs, if you haven't already, and the repop plastic lenses. I found the plastic lenses allow significantly more light to pass through and when paired with the 21cp bulbs are more than adequate for day and night driving. Plus they'll look more original than a third brake lamp. Just a thought. Here's a comparison of the two... http://www.flickr.com/photos/ericdifate/6321986157/ | | | | | Joined: Jun 2009 Posts: 789 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 789 | Thanks for looking out for me. I have added the 21cp bulbs and have bought a pair of NOS plastic lenses. I am pleased with both additions. However, I just can not stand the thought of a rear-ender on one of my road trips here in Michigan! | | | | | Joined: Jan 2001 Posts: 1,422 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,422 | Can you share a close-up picture in the daylight of what you are using, along with how you have it mounted? Thanks. Just went down to take a couple pictures of my new and improved version . These are two individual license plate lights. My wife was driving behind me one night and said the third (and fourth) brake lights were fantastic...they're directly in your field of vision. In fact, because they are license plate lights they 'pop' the white college plate I have making the whole assembly a foot and a half of high visibility. I realize that my solution is not for everyone but it is very functional and unlike most, if not all, I am a daily driver only vehicle. Regards, Cosmo
| | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | Luke: I have one of these Brakelighter units installed on my '37 Half Ton. I chose to only use the suction cup mounting option since I sometimes show the truck as "mostly original". I like the added safety and several of my buddies have commented they like the brightness and added visibility for my braking or turn signals. I will add one to my '46, when I get to that stage.
Before I bought it I heard some comments that the LED lights would reflect off the back window and be a distraction. I have not noticed that as a problem. It might be because of a difference in the glass shape between a truck and car? | | | | | Joined: Dec 2007 Posts: 23 New Guy | | New Guy Joined: Dec 2007 Posts: 23 | Look at this...this is a removeable light. Put in your rear window while on the road and remove it when you do not want to use it. Requires no alteration to your truck, but you will have to work on the 6v/12v issue. You may contact them to see if they can accomodate you with a 6v version. http://www.brakeflasher.com/brake_al.htm
Don 1950 Chevy Panel Delivery. Purchased in 2008 that was in a family for 35 years. Restomodded in 2006.
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | ...but you will have to work on the 6v/12v issue. You may contact them to see if they can accomodate you with a 6v version... Says right on the page you linked to "It only draws 100 ma, and it operates on 6 and 12 volt electrical systems, positive or negative grounds." I might have to look into one of these. I like the plug feature and magnets. | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Brad...that stop lite is so cool. Where oh where did you find it  | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Dogface - Not sure where Brad found his but I got mine on ebay. Some are old bus, police or ambulance lights, and others are intended for general automobile use. I've found the general use ones tend to go pretty high as far as cost so I hunted around for a bit and snagged this one for under $100 It's a c.1921 Protex Signal - http://farm8.staticflickr.com/7180/6924279335_7be8101d08_z.jpg | | | | | Joined: Jun 2009 Posts: 789 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 789 | Here are some photos of what I decided to do with adding a 3rd brake light--safety was my main objective, along with maintaining a vintage look: http://s160.beta.photobucket.com/us...mp;_suid=1362925456609046217878436328036I appreciate all the suggestions that came my way, both in public and via PMs. This is absolutely the best on-line forum for us Stovebolt hobbyists...a great group of people willing to help one another with info. and ideas. Keep on truckin'...now if we can just get the snow, ice, and salt off our Michigan roads--fixing potholes would be appreciated too! | | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | Looks good and is a Great Idea!!!! I like it!!! | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That's pretty cool. Thought about doing something similar myself, but manged to get this instead. It's a NOS Hollywood Accessory Model 544 Safty Lite. I plan to mount it on the front bed panel, similar to how yours is mounted.
Bill Burmeister | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I like the signal function of the brakelighter easy to install also | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | I think you guys have a good idea here. Stock tail/brake lights are just too small. There are tons of neat ones on flea bay to look at...some more affordable than others. I'd hate to get rear ended too... | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Would you consider using a Harley taillight ? They are period correct but would require mounting on the roof. I bought one to mount on my suburban but changed my mind. It looks like the panel barn door lights, but have a curvature that usually mounts on a fender. I think you can get LED lights for them too. | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Blue: Mine looks similar..just found it on ebay a couple days ago for $80 (ouch) bit it does look vintage cool. It has not arrived yet but from the pics appears to have some kind of sheet metal bracket and a wire or two coming out the back in a metal loom thing. I guess I'll need to find the Pos brake feed coming into one tail light to get it to work. If you recall what color that brake lite wire is it'll save me some time/testing... Mine, I think will mount on that center bolt hole on the bumper like Brad did. I love the idea of adding an extra since the OEM ones are so small. We don't have much traffic in this small town but it's better to be as safe as possible...and still look vintage,.. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | HOW WOULD YOU MOUNT THIS ONE? It operates hydraulically when you are turning and operates as a tail/brake light when signal is off. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you'd need to add a ground wire, from under the rubber against the case to where the bracket mounts to metal, aside from the screws being totally insulated from the bracket, the threads into the case will corrode enough to give ground problems before long .... the other way would be 2 wires into the light, the hot one and a ground that terminates on the frame under the bed
Bill | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Thanks Bill I had considered adding that ground wire and will do  . I figgered it might be added insurance, but never thought that the screw holes would corrode that much. Edit: I do know, however, that faulty grounding is a major cause of elec. issues in all vehicles.
| | | | | Joined: Jun 2009 Posts: 789 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 789 | Here is a link to 2 pictures of the new and improved version of my 3rd brake light: http://s160.photobucket.com/user/st...amp;_suid=136529696109300613151999808082It is a reconditioned 7" Grote model 250 with a glass lens. The bucket had to be cleaned up, the glass lens was a caked mess of grime, and the stainless steel ring needed some attention. It should provide better visibility than the 3rd Guide taillight that I had originally installed. I really do appreciate the ideas and advice that everyone has provided. | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | I like it...looks a lot like mine from an old school bus. You did a nice job on the rails too
| | | | | Joined: Dec 2012 Posts: 19 New Guy | | New Guy Joined: Dec 2012 Posts: 19 | I want to add a third brake light like Dogface's.
I have a turn signal that uses the brake light as a brake light and a turn signal.
Can I just run another wire back from my brake switch to the third brake light.
Appreciate the help
1952 Chevy 3/4 ton 1948 Simplex Motorcycle 1930 Ford Model A Coupe 1928 Ford Model A Station Wagon
| | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | I would think that the best way but I'm far from really knowledgable on the subject. I found mine on flea bay just searching for 'vintage stop light'
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | No reason for it not to work that way. that's how I'm going to wire mine up. A little tip for hunting for vintage stop lights on Ebay; don't limit yourself by just searching "vintage stop light". Do a search in vintage parts using "stop light" or "vintage lighting". You would be amazed at what you might miss by just doing one type of search. I found mine by searching "vintage lighting", it never popped up when I searched for "vintage stop light" or "stop light".
Bill Burmeister | | | | | Joined: Dec 2012 Posts: 19 New Guy | | New Guy Joined: Dec 2012 Posts: 19 | Just copying others great ideas Third Brake LightIt works great
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I fitted one in my back window I also opted to fit LED tail light and amber bed roll turn signals at the rear. Admittedly European lighting regs are slightly different to the USA. I'd rather sacrifice a little originality in the interest of safety. I masked off the area on the glass and used glass primer to form a black surround then stuck the light to the window with 3M double sided tape,only one hole was drilled for the ground wire and the live was fed through a grommet to my brake switch and is easily removed if I ever need to.
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jun 2011 Posts: 150 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 150 | | | |
