| | | Forums66 Topics128,052 Posts1,055,725 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | My wife coined up and purchased a Delta bench grinder as a Christmas gift. Anyhow, it seems to be built very good, regardless of where it is now manufactured. My only dissappointment is that one of the grinding wheels doesn't run true. It wobbles back and forth as though it's loose. I swapped the wheels side to side and even put an old grinding wheel on. It seems as though it's the "new" grinding wheel.
So, here is my question. How true should a grinding wheel run?
Chris | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Should run true with no wabble. Even if the center hole was not bored perfectly perpendicular to the sides the large support washer should hold it true against the flange on the shaft. The only thing that could run out that could be trued up is the O.D. which you can and should dress true anyway.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | There isn't any problem with the RH side wheel, so I swapped sides and it runs true on both sides. I'm thinking maybe the center hole may not be drilled straight or it's just a junk wheel. I'm planning on swapping it out for a wire wheel anyhow, so it's no big deal.
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I also got a new bench grinder for Christmas (Porter Cable) with the variable speed feature and it's very nice. Only problem seems to be in finding good steel wire brush wheels. All I find are either brass or twisted wire which I don't want. So if anyone knows where to find decent (not cheapo Chinese crap) wire wheels I like to hear about it. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | McMaster Carr. They've got about any brush you will ever need for your bench grinder. They will deal with the retail public as well as the commercial customers and their delevery is fast also. http://www.mcmaster.com/#wire-wheels/=kzlcj2 Stay away from the hardware stores or places like Harbor Freight. Denny Graham Sanwich, IL
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Thanks Denny, I was able to find the one I have been looking for. Say what? Somethings fishy here.
| | | | | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | Yeah, I know, I'm working on it. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | | | | | | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | | | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | I guess I'm lucky, I'm within 10 minutes of a Grainger and a Fastenaal store. Sadly, most of the grinding stuff is Chinese made, but there's some US and Canadian suppliers in there too.
"Happiness equals reality minus expectations" - Tom Magliozzi
