1 members (baldeagle),
34
Mod | | | Forums66 Topics128,003 Posts1,055,244 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 27 | I'm building a '57 235 block bored .080 over, with a '59 848 cylinder head, 261 grind cam, offy two pot manifold with the carter/weber 2 bbls and fenton headers. My original engine (I have a '62 C10 Stepside) has the remote oil filter that was originally mounted to the intake manifold...I believe this is called a bypass filter system. Is there anyone that offers a spin-on filter adapter? If not, can someone please educate me on how the current filter system works, what oil pressure is desireable/expected from the newly rebuilt engine and where I might be able to mount the filter since it's not going to fit on the Offy manifold. Your input is much appreciated.
_________________________
'62 Chevy C10 Short Bed Step Side, 235 Six with Offy intake, 2 carter/weber 2bbls and Fenton headers. B-W T5 5 speed trans, with stock rear end.
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | If you are building the motor, look in the tech tips for an article on hjow to convert the engine to full flow oil system. Then you can have a modern spin on filter and mount it just about anywhere.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | if it is a bypass system, it only takes a tiny percentage of oil from the gallery and runs it through the filter and dumps it straight into the pan. The oil that goes to the engine itself isn't actually ran through a filter before it gets to the bearings. you could use a spin on filter as a bypass, but the micron rating isn't as low as one for the bypass unit. And you would need to put some form of restriction in the run at some point or all your oil pressure will go away. (remember it just dumps back into the crankcase.) If I am not mistaken there is a tech tip just for this sort of thing on this forum. There are many opinions about how this compares to a full flow filter, all I know is they quit using this system many years ago and cars now days run 3 times as long as these used to. However lubrication technology, machine work, fuel mangagement (cuts down on the amount of excess carbon in the oil) has improved so dramatically it is hard to tell what the actual cause of longevity may be. If you want to use the bypass unit you can put it anywhere you have room that suits your fancy. I have seen a lot of them on the firewall. A full flow unit will require a bit more work, and since I am not so familiar with a 57 block, that will have to wait for Dave. But whatever the case you will have to get a filter block from napa or some such, fab up some sort of bracket and mount the filter where you can, and run lines to and from it. As far as I know no one makes a bolt on kit. The best tool you can get is the manual which should give you a very thorough and complete description of the entire oiling system. I do know the 54 oil pump has a 45 psi relief on it. I would say 20 psi hot at idle and 30 or so running, (thats what I get anyway) | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Jim Carter now sells a remote filter head for use with a spin on filter. This has supposedly been ported for use as a by-pass filter head that could be placed anywhere where it is conveniently accesible. Jim Carter by-pass filter head | | |
