1 members (Forty9),
113
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,072 Posts1,055,903 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#90732 04/21/2003 5:53 PM | Joined: Apr 2003 Posts: 4 Junior Member | | Junior Member Joined: Apr 2003 Posts: 4 | Hi Folks--I'm new to the forum here and new to a 53 chev 3/4 ton PU. I finally got out to have a look at it the other day and need some guidance. For background--the truck hasn't run for 6-10 years.
On sat I took a battery out of my other truck, hooked it up and was going to check that it turned over--then that we got a spark--then fuel... So it turns over which is a good sign, but I couldn't get a spark. I thought it might be the coil so I replaced--still not getting a spark.
The line into and out of the coil are hot. Any suggestions?
Also curious if anyone can recommend a decent shop manual source for this type of truck as this is my first attempt at auto mechanics and I am relatively clueless...
Thanks in advance. | | |
#90733 04/21/2003 6:07 PM | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | Points, condenser, rotor, cap, plugs, wires... any or all of these could need replacing.
Chevy Duty sells reprints of the shop manual.
edit: You said that you pulled the battery out of the other truck, am I to assume the '53 has been converted to 12v? If so, do you have a voltage reducer between the ignition and coil? | | |
#90734 04/21/2003 6:14 PM | Joined: Aug 2001 Posts: 13 Member | | Member Joined: Aug 2001 Posts: 13 | This website will get you started for info on manuals and the FREE Chevrolet restoration package: http://www.50chevy.freeservers.com/Catalogs_and_Manuals.htm As for getting spark, check all grounds -- including grounding straps, worn-out wires, and rusted connectors. | | |
#90735 04/21/2003 6:18 PM | Joined: Apr 2003 Posts: 4 Junior Member | | Junior Member Joined: Apr 2003 Posts: 4 | OK. Thanks for the quick reply. Yes--it was converted to 12V at some point.
Any reccomendation for which I should start with? I assume I can get new points at a regular auto parts store. I'll get the shop manual online today and start my education.
thanks again. | | |
#90736 04/22/2003 1:52 AM | | Anonymous Unregistered | | Anonymous Unregistered | This thread might save you a little time and $ as far as narrowing down the problem.  | | |
#90737 04/22/2003 6:01 PM | Joined: Mar 2003 Posts: 30 Junior Member | | Junior Member Joined: Mar 2003 Posts: 30 | if your coil is showing 12 v on both term your points are rusted open, if it were me points,cond,rotor,cap,wires,@plugs would be the way to go  | | |
#90738 04/22/2003 6:48 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | And don't run it with the fuel in the tank. Bring a small can and hose to run it from.
54 3100 with 235 62 flatbed dump C60 with 261
#90739 04/22/2003 7:04 PM | Joined: Apr 2003 Posts: 4 Junior Member | | Junior Member Joined: Apr 2003 Posts: 4 | OK. Thanks for the advice--I'll get out there later in the week. I'll start witht the points. | | |
#90740 04/23/2003 3:19 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | When you do look at the points, make sure they are closed on the flat side of the distributor cam(under the rotor) andthat they will open to about the thickness of a matchbook cover when the distributor cam pushes the points open.(if you need to, use a matchbook cover or an actual feeler guage. 16 to 18 thousandths)
#90741 05/13/2003 7:07 PM | Joined: Apr 2003 Posts: 4 Junior Member | | Junior Member Joined: Apr 2003 Posts: 4 | It was the points--they were corroded and not adjusted properly--I cleaned them up and was able to get a spark. We'll see if I can get fuel this weekend. Thanks for your responses. | | |
#90742 05/15/2003 8:45 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Cool news Keep us informed on how the patient is doing
#90743 05/15/2003 1:24 PM | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | I had this problem with a girlfriend and found that changing girlfriends fixed it. Don't know if that will work in your situation. | | |
#90744 05/15/2003 1:27 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | I bet you got plenty of spark off the previous one
#90745 05/16/2003 2:38 AM | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | it must have been the flux capacitor draining the finnegan pin | | |
