4 members (Gdads51, Joe H, Otto Skorzeny, Gray_Ghost), 99 guests, and 5 robots.
Topics128,065
Posts1,055,865
Members48,428
#90732 04/21/2003 5:53 PM
Junior Member
Junior Member
Hi Folks--I'm new to the forum here and new to a 53 chev 3/4 ton PU. I finally got out to have a look at it the other day and need some guidance. For background--the truck hasn't run for 6-10 years.
On sat I took a battery out of my other truck, hooked it up and was going to check that it turned over--then that we got a spark--then fuel... So it turns over which is a good sign, but I couldn't get a spark. I thought it might be the coil so I replaced--still not getting a spark.
The line into and out of the coil are hot. Any suggestions?
Also curious if anyone can recommend a decent shop manual source for this type of truck as this is my first attempt at auto mechanics and I am relatively clueless...
Thanks in advance.
#90733 04/21/2003 6:07 PM
Points, condenser, rotor, cap, plugs, wires... any or all of these could need replacing.
Chevy Duty sells reprints of the shop manual.
edit: You said that you pulled the battery out of the other truck, am I to assume the '53 has been converted to 12v? If so, do you have a voltage reducer between the ignition and coil?
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#90734 04/21/2003 6:14 PM
This website will get you started for info on manuals and the FREE Chevrolet restoration package:
http://www.50chevy.freeservers.com/Catalogs_and_Manuals.htm
As for getting spark, check all grounds -- including grounding straps, worn-out wires, and rusted connectors.
#90735 04/21/2003 6:18 PM
Junior Member
Junior Member
OK. Thanks for the quick reply. Yes--it was converted to 12V at some point.
Any reccomendation for which I should start with? I assume I can get new points at a regular auto parts store. I'll get the shop manual online today and start my education.
thanks again.
#90736 04/22/2003 1:52 AM
Anonymous
Unregistered
Anonymous
Unregistered
This thread might save you a little time and $ as far as narrowing down the problem. wink
#90737 04/22/2003 6:01 PM
Junior Member
Junior Member
if your coil is showing 12 v on both term your points are rusted open, if it were me points,cond,rotor,cap,wires,@plugs would be the way to go smile
#90738 04/22/2003 6:48 PM
And don't run it with the fuel in the tank. Bring a small can and hose to run it from.
54 3100 with 235
62 flatbed dump C60 with 261
#90739 04/22/2003 7:04 PM
Junior Member
Junior Member
OK. Thanks for the advice--I'll get out there later in the week. I'll start witht the points.
#90740 04/23/2003 3:19 AM
When you do look at the points, make sure they are closed on the flat side of the distributor cam(under the rotor) andthat they will open to about the thickness of a matchbook cover when the distributor cam pushes the points open.(if you need to, use a matchbook cover or an actual feeler guage. 16 to 18 thousandths)
#90741 05/13/2003 7:07 PM
Junior Member
Junior Member
It was the points--they were corroded and not adjusted properly--I cleaned them up and was able to get a spark. We'll see if I can get fuel this weekend. Thanks for your responses.
#90742 05/15/2003 8:45 AM
Cool news cool
Keep us informed on how the patient is doing grin
#90743 05/15/2003 1:24 PM
I had this problem with a girlfriend and found that changing girlfriends fixed it. Don't know if that will work in your situation.
#90744 05/15/2003 1:27 PM
I bet you got plenty of spark off the previous one eek grin
#90745 05/16/2003 2:38 AM
it must have been the flux capacitor draining the finnegan pin
