7 members (Southerntruck, Lostbuthaulinass, Otto Skorzeny, gswbbc, Hotrod Lincoln, 2 invisible), 49 guests, and 3 robots.
Topics128,032
Posts1,055,521
Members48,425
#907399 12/30/2012 1:45 PM
I installed an Edlebrock carb and I'm trying to connect the linkage. The stock setup will work but I can't find a way to connect it the carb. A heim joint or something similar will work.The main problem is the fine threads, they are wierd not 1/4-28 something finer. I posted this in the engine blog no replies. Any help would be great.
Thank you Brett Merry Christmas and a Happy New Year
perhaps metric?
ron
I think #10-32 is common...
Look at speedwaymotors.com.
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
Thanks for the ideas. I talked to a friend, he said he drills out the stock piece and add a washer and cotter pin.
