| | | Forums66 Topics128,060 Posts1,055,833 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 304 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 304 | Does anybody know if u can buy the half round locking "clip" that holds the bolts tight on an enclosed driveshaft? It goes over the u-joint, is half round , has the two bolt holes and locking tabs. My locking tabs are broken and just want/need ? to replace them (2). I guess I could always remember my F-4 Phantom days and just find some correct bolts to safety wire the bolts. Or am I just worrying too much?
'52 3100 "once a Marine, always a Marine!! | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I got new ones with the rear end gear set from Patrick's Call Patricks and ask if they will sell you some. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | chevs of the 40's has both the special bolts and the retaining clip. If those bolts come out it gets very ugly in there, I took mine apart after 28 years and now I know why the fella I bought it from rebuilt the transmission,(at least said he did) the bolts had obviously came out at one time. The bolts, the yoke, and the little ball joint areas was all beat up. He didn't even bother to dress the high spots caused by the carnage,just bolted it back together. Leading me to wonder what sort of work was done on the transmission. | | | | | Joined: Nov 2010 Posts: 304 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 304 | Thanks everyone. Just ordered a couple. Knew they had to be there for a reason!!!
