Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (68ironhead, Bill Hanlon, Waveski, Otto Skorzeny, Jon G, 2 invisible), 129 guests, and 6 robots.
Topics128,283
Posts1,058,513
Members48,490
#906146 12/25/2012 3:11 PM
I just picked up at set of six Yokohama 8r17.5 tires on old dually dodge motorhome wheels, the tires are almost new maybe 5000 miles on them, the problem is that they are a little dry rotted, as they usually are coming off a camper. They all hold 80lbs of air they have no plugs or patches, other then the lite dry rot they are like new, they have no real deep cracks. My question is is running dry rotted heavy duty 10 ply tires a bad idea?? Has anybody done it with out any real,problems?? AIl my redneck buddy's here in Ky told me to rub the cracks in the tires with Vaseline fill them full of air and run them till they wear out. Being that it has taken me 2years to find a set forsale on craigslist or anywhere for that matter, that I can afford I'm thinking I'm Gona have to take a chance.
Don't do it, it's not worth the risk. This is especially true if the tires are any more than 4 years old.
Bill Burmeister
D A N G E R O U S .....
Don't listen to your Redneck friends or they will be going to a funeral and it won't be theirs.
If they were nylon bias tires, I wouldn't worry about them. However, radials are a different animal all together. I make sure the date is within 4 or 5 years. Sitting around without occasional use is especially dangerous. And the fact that they are inflated to 80 psi makes them especially vulnerable to a blowout. In addition to my over the road equipment, I have about a dozen storage trailers. Radials routinely blow out on the storage trailers that are just sitting there. I have recently began deflating the tires on the storage trailers to about 35 psi and they seem to be less prone to blow out.
OK. Just close your eyes and say it: "I am going to drive down the road on rotten tires." Visualize itt... are you with me? PULL OVER!! Don't do it if there is any doubt. You cRazZY?? This is the contact point with the road, my man, with +/- 1000 lbs riding on each tire depending on your rig / load. Stop being silly. Junk 'em. Work nights at a pizza delivery so you can afford some decent tires.
Stovebolts are like women; as they mellow with age, it's harder to get 'em to turn over on a cold morning, but once they're warmed up, LOOK OUT!
If they're not showing any signs of seperation,(odd humps) then I'd run them. I'm still running the 7.00 18 tires that were on my '49 when I drug it out of the field. It's been on the road for two years now, with no problems. The dry rot on my tires is way beyond light, but they keep on rolling. It all boils down to what you feel comfortable with.
edit: My tires are bias ply. I don't know how ancient radials behave.
remember bias ply tires usually have tubes radials do not... think on that a little!
Dance like no one is watching,
Sing like no one is listening,
Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420
1948 GMC FC253 1t Factory 80"x9' Flatbed Dually
1948 Chevy COE 2 Ton 8'x15' Flatbed
1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton Cab and Chassis
1942 Clarkator 6 MILL-44 Heavy Aircraft Tug
1942 Ford (9N) Moto Tug with 1/2 yard Loader
1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
If the rubber in the tire casing is in poor condition, it won't matter if it has a tube in it or not. Also, the rubber in the tube is most likely as old as the tire itself, and will also be degraded.
Bill Burmeister
Don't do it, especially if they are radial tires, you run the risk of having them "zip" on you, not a good thing as the sidewalks will rip out violently, and then you run the risk of loosing control of your vehicle if you are driving, even more scary if you are airing them up.
1966 Chevy C 30 1 ton truck
Moderated by  Dusty53
