0 members (),
234
9
Mod | | | Forums66 Topics128,078 Posts1,056,052 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | Is there such a thing?
I'm going to have a hard time fitting the 292 in my 40 with the standard pump. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They changed the pump/pulley setup in about 74 or 75. It went to narrow belts & a smaller dia. bypass hose. Weather it is shorter, i'm not sure about. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The 194,230,250 pump fits a 292. They come in a very short version. I put a 292 in a 40 a few years back without moving the radiator. I also use a flat face flex fan. You do not need the by-pass set up for car or light truck use.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | Did you keep the stock water pump on the 292 or swap it out?
Any tips on the motor mounts? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I used the shortest 194,230,250 pump. I do not remember the exact application. I have done so many jobs since then, I do not remember exactly how I mounted it.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | While the 194,230,250 water pump physically fits the 292, it does have an additional circulation hole in the backing plate. However, as pre'68 Dave notes, it can be used successfully on a 292 if it seals properly to the block.
Drew
