0 members (),
102
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#90675 01/24/2005 8:35 PM | Joined: Nov 2000 Posts: 44 Junior Member | | Junior Member Joined: Nov 2000 Posts: 44 | I'm in the process of collecting all my parts to make the conversion from 6 to 12 volt. I was wondering what type of 12v coil to look for to fit my 216 engine or does it matter much? | | |
#90676 01/24/2005 8:45 PM | Joined: Jul 2004 Posts: 102 Member | | Member Joined: Jul 2004 Posts: 102 | doesn't matter much, but it might be a good idea to bring the old 6v in with you to check sizes so it fits in the little holder on the engine. also remember to get the resistor for it.
1948 3600 thriftmaster
#90677 01/24/2005 9:48 PM | Joined: Nov 2000 Posts: 44 Junior Member | | Junior Member Joined: Nov 2000 Posts: 44 | Thanks for the reply Gecko. I was noticing in your post about converting to 12v you are still using your amp gauge. I thought I had to switch that for a volt gauge when I make the conversion to 12 volts. Can I skip this step and get by with my original amp gauge? | | |
#90678 01/24/2005 11:10 PM | Joined: Jul 2004 Posts: 102 Member | | Member Joined: Jul 2004 Posts: 102 | I'm not any authority on this stuff, but I have never heard you have to switch to a volt meter. Mine works well, and I've been using it for several months now. Don’t under estimate how tough some of these components are, I was running my truck with 12 volts for about a month without disconnecting the gas gauge, I figured it was fried, so I didn’t bother. Yesterday I hooked it up properly to the sender and it worked perfectly, not fried at all.
#90679 01/25/2005 7:45 PM | | Anonymous Unregistered | | Anonymous Unregistered | Crow, if you are still running a points type ignition you will want either a coil with a built in resistor, or, if you choose a coil without the resistor, you will need to install an external ballast resistor in the 12v supply wire to the coil. If you run the full 12v to a coil without a resistor, your points will burn pretty quickly. If you are running HEI or other electronic ignition that doesn't use points, then it's not an issue(although Pertronix still advises dropping the voltage to the coil for their conversion kits). | | |
#90680 01/28/2005 6:57 AM | Joined: Jan 2001 Posts: 230 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 230 | Your ammeter cares not a whit about voltage , all it does is measure the amperage so don't worry about it .
You'll fry the fuel gauge in 5 seconds if you run 12 volts through it though .
-Nate There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
#90681 02/04/2005 1:55 AM | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | Get a 55-57 Chevy coil with a built in resistor. They look very close to stock coils, if that matters to you. Cecil..... | | |
