0 members (),
58
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 84 Shop Shark | | Shop Shark Joined: May 2008 Posts: 84 | I own a 57 3100 with a hydramatic transmission. I took it out for a spin today im estimating it topped top out at 50-55 mph. With new 640 15 tires stock rear end. What is the top speed for these trucks with a 235/hydra? Bolt on rear end conversion? Thanks in advance. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What is the rear-end ratio? That will be the primary factor.
Do you have a rear-end conversion? Or, do you have the stock rear end (is that a 3.90)?
A 640 15 bias ply tire would have about a 27" diameter.
| | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | The H-M transmission high gear is 1:1. Same as a standard. The H-M also does not have the slippage of a modern automatic trans. Bottom line is that it will run the same speed as it would configured the same way but with a manual transmission. | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Chevrolet 1957 Specifications-Truck http://www.gmheritagecenter.com/doc...hevrolet-Trucks/1957-Chevrolet-Truck.pdfEngine speed piston travel PDF page 128 (bottom of page) 4 speed Hydra-Matic Axle ratio, tire size, engine rpm @ 1 mph rpm 1st,2nd,3rd,4th gear feet per minute calculation on PDF page 129 (bottom of page) Engine performance on PDF page 99 Hope this helps. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Let's pretend that you have 27" tires, and a standard 3.90 rear end, and a final transmission gear ratio of 1:1 At 55 MPH your engine RPM would be about 2700. A little high, but not really straining the engine. The cheapest way to get lower RPMs and higher speeds might be to get larger diameter tires. 30-31" tires would get you 2500 RPM at 60 MPH. | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Tim, Nice Engine RPM cakeculator, I mean calculator. I bookmarked that one! | | | | | Joined: May 2008 Posts: 84 Shop Shark | | Shop Shark Joined: May 2008 Posts: 84 | I dont know the gear ratio. Im just trying to be able to drive the truck occasionally on the freeway and improve mileage if possible. Thanks | | | | | Joined: May 2008 Posts: 84 Shop Shark | | Shop Shark Joined: May 2008 Posts: 84 | I know its stock 6 lug. Any suggestions on a donor rear end will bolt right in with the least modifications required? | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Take a look at Patricks Antique Cars & Truck partsWhen get to the page there is a separate side scroll bar,scroll down to page 13 about half way down, you will see a picture of a pickup with the word NOW in the picture. High-Speed Rear Ends'55-'62 pickup 1/2 ton 3.38:1 ratio ring and pinion installation kit
You should be able to cruise at 65-70 mph with 3.38:1 ratio rear end. And get pretty good fuel economy. After calling Patrick's. Let me know what you find out. Thanks, Added more 3.38:1 ring and pinion installation kit links: ringpinion.com tomsdifferentials.com
| | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | the 3.38 is for the later open rear end assembly. The best you can get for up to 54 torque tube style is 3.55 | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The tires you're running are a bit undersize for your truck. The base size for the '55-'59 3100/3200 was 6.70-15. According to the specs I've looked up on the tire dimensions, the tires you have are about 1 1/4" smaller than the stock size, the 6.40-15s being approximatly 26.88" and the 6.70-15s being approximatly 28". Therw will be some varaince depending on manufacturer/tread design/inflation pressure. With the OE diameter tires and 3.9 rearend ratio, it looks like you would be turning a bit over 2600 @ 55 mph.
Bill Burmeister | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | It's a 57 so it is an open driveline. | | |
