8 members (tclederman, 68ironhead, 3B, GMCJammer51, Otto Skorzeny, Pre '68 Dave, Jon G, 1 invisible),
124
Mod | | | Forums66 Topics128,110 Posts1,056,245 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 11 New Guy | | New Guy Joined: Dec 2012 Posts: 11 | I have a 53 chevy 3/4 ton with original split rims that are 8 lugs. Tire shop doesn't want to touch them for me. I would like any input on wheels I could replace these with. 15" or 16". I wish I could use my original hubcaps though! They look great and they match my overall color scheme. Any ideas would be great thanks | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | tru design wheels in denver co will take your rims apart and weld new ones to your original wheel hubs it's pricy but you can keep your 8 lug wheels and use your hubcaps pm me if you want the number
rolf
1963 c10 | | | | | Joined: Dec 2012 Posts: 11 New Guy | | New Guy Joined: Dec 2012 Posts: 11 | any other options like wheels off an older 3/4 ton that will allow use of my hubcaps? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | There are numerous posts on this topic. I will share with you what I did because I retained my original hubcaps. The rears will bolt right up, I used wheels off a 1991 Chevrolet Suburban 3/4-ton. The fronts will not clear in most cases without work. I modified my steering arms and tie-rod ends for clearance. Search through some of the posts for other ideas. PM me if you want all the details on how to attach the hubcap clips and modify the front end pieces. Here is picture link you can see my caps/truck. http://www.flickr.com/photos/advance-design_parts_co/8129054429/in/set-72157631867396207 | | | | | Joined: Sep 2010 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 32 | Have you tried a "real" tire shop that does heavy trucks, equipment, etc? This shouldn't be a problem for them. | | | | | Joined: Dec 2012 Posts: 11 New Guy | | New Guy Joined: Dec 2012 Posts: 11 | thanks guys, that'll give me some ideas to toss around! | | | | | Joined: Dec 2012 Posts: 11 New Guy | | New Guy Joined: Dec 2012 Posts: 11 | So i can just tack weld the hubcap clips on? Or maybe put some small bolts through the wheel to hold the hubcap clips on? | | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | Hey matt, i did a lot of work on this and posted photos. If you search for harryr posts, the original post was no 748598. Let me know if i can help.
Harry
748598 | | | | | Joined: Dec 2012 Posts: 11 New Guy | | New Guy Joined: Dec 2012 Posts: 11 | | | |
