6 members (Otto Skorzeny, 3800GUY, Gdads51, KEVINSKI, TooMany2count, 68ironhead), 120 guests, and 0 robots.
Topics128,110
Posts1,056,251
Members48,437
#905334 12/21/2012 9:13 PM
SO I HAD A 235 IN MY 53 1\2 TON, i SOLD THE ENGINE AND GOT ANOTHER 235 WITH THE SHORT PUMP, BUT NOW THE FAN WANTS TO SCRAPE THE RADIATOR, OOPS sprry for the capitols. do u guys THINK I JUST NEED A NEW FAN? relocate radiator brackets? remove fan and add a electric? i dont understand why its not wanting to fit now
You need to use the old style pump and a water pump adapter. Water Pump Adapter
1951 1 Ton Completed
it worked before with the same year 235, but this one scrapes one of the blades. Id rather not drill/tap my block.
Perhaps one blade is a little more bent?
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
thats what im assuming. the radiator support isnt adjustable is it? weird thing i ran the motor for about 15 min the other day with the radiator in place and it wasent rubbing,
Are all the motor mounts in good shape and bolts tightened?
Weird thing I got a radiator from the guy I bought the engine from, and it's thinner then the radiator I had? The one with r11 a 53 d is thick and the 53 k is thinner and clears? How queer
Can you post some pictures of the short pump and fan ?
1951 3100 Chevrolet
Are you sure the water pump is good, no shaft play?
I have a 55' 235 in my 53' and replaced the pump woth one from Patricks. I have a fan clearance problem too but solved it with a set of Morroso fan spacers and a fan from a 56' 265 engine. Never had any heating problems even on the hottest days. Check it out at the photos in the link below.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
sps Offline
Are you shure it was a 235. 53's had 216 engines in them. I had to set my radiator forward when I put my 235 in my 53.
53s had 261S? No , not this truck, its a 235. I got it to work buy adding a few shims under the radiator support. works fine now!
Leo Offline
Moderator
Moderator
My '53 half ton panel had a 235 in it, changed it out for a '60 261. No issues at all with the water pump or fan touching the rad.
sps #906536 12/27/2012 12:58 PM
Originally Posted by sps
Are you shure it was a 235. 53's had 216 engines in them. . . .
What year 235 car/truck engine did you take out of your truck?
What year 235 car/truck engine do you now have in your truck?
sps's question about a 216 is appropriate, because only a 216 engine was originally available in a 1953 3100 truck.
oops, i though sps said 261 came in 53's i misread. no it had a 56 235 in it and i sold that to a buddy and put another 235 in it.
