| | | Forums66 Topics128,139 Posts1,056,462 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I work on these old radios because I enjoy doing so. There are members here who have a lot more experience than I do. For me, the easiest part is the electronics. I find the mechanical aspects can be a real challenge.
The double gears that interface with the worm drive have always been a source of intrigue for me. Well now I have come across a Delco instruction on how to adjust them. When they are not adjusted correctly you end up with that annoying play in the dial drive.
Basically the gear to the left, looking from the front of the tuner is not attached to the shaft. It is connected to a spiral spring. To adjust it, move the worm drive away from the gears by removing one of the mounting screws, rotate the left gear against the spring to the limit, back off four teeth and them re-engage the worm drive.
I hope this information helps. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Fred, where did you find the Delco instructions? I would like to have a copy if possable for my reference file since several times a year on of them ends up on the radio bench. Thanks for the tip. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Denny, I will find it and send it to you.
Merry Christmas,
Fred | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thanks Fred and a Merry one to you also. I try to feed the reference file with as much documentation as I can. Denny G
