4 members (RoadsScholar, DadsFirstPickup, Maybellene, Cletus1950), 128 guests, and 5 robots.
Topics128,108
Posts1,056,233
Members48,437
#905904 12/24/2012 2:50 PM
I
I Offline
I have purchased a set of Fenton Headers, an Offy 2 pot manifold, 2 Holley/Weber 2bbls from Langdon's to install on my newly overhauled engine. My question involves the original engine exhaust and intake "rings" that are placed between the head and the manifolds. Several of my originals are no longer serviceable and I can't seem to find them listed in any parts catalogs. Can I get by without them or can you recommend a source?
'62 Chevy C10 Short Bed Step Side, 235 Six with Offy intake, 2 carter/weber 2bbls and Fenton headers. B-W T5 5 speed trans, with stock rear end.
Jim Carter lists them as a engine intake ring Part # ME236 or ME237
1934-53 alignment rings
1954-62 alignment rings
Holley-Weber or Carter-Weber carburetors?
I
I Offline
Carter-Weber is indeed correct. Thank you.
I
I Offline
Thanks, I ordered a set from Carter. One more step toward assembly!
