4 members (Jims46, Hotrod Lincoln, klhansen, Deegs53), 241 guests, and 0 robots.
Topics128,088
Posts1,056,114
Members48,434
#90535 09/04/2004 10:37 PM
Junior Member
Junior Member
...the speedometer...
Hey' bolters... finally got around to installing my new dash board into the '65 GMC... went for Autometer antique-looking guages... Volts read 14.3, temp reads 200 degrees, cooling fan on, 180 degrees off, oil pressure reads 25 to 40 psi depending on engine speed... Fuel guage I couldn't get to yet, but not concerned right now...
However... the speedometer reads nearly 15 mph off... Vehicle speeds is say 50 actual and indicated speed is, maybe 35... This I would like to correct somehow... I have no idea on how accurate the OEM was, it was trashed before I got it....
Any ideas?
Any help, as usual, greatly appreciated...
Thanks, Pete
Pete in NE PA
1964 Cheverolet Carryall
1965 GMC 1/2 ton
I would guess and say it is probably your
rear tires. When the speedometer was made, it
was set for a certain diameter size tire.
You can check on the factory stock size and
compare it to what your running. Also, if you
changed you tranny or rearend, this will
affect the speed indication too.
Most modern automotive speedometers indicate 60mph at 1000 rpm cable speed. You should be able to get an adapter from a speedometer shop or you can change your drive gear in the transmission.
Paint & Body Shop moderator
