2 members (Otto Skorzeny, 1 invisible),
107
Mod | | | Forums66 Topics128,193 Posts1,057,253 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | SO I HAD A 235 IN MY 53 1\2 TON, i SOLD THE ENGINE AND GOT ANOTHER 235 WITH THE SHORT PUMP, BUT NOW THE FAN WANTS TO SCRAPE THE RADIATOR, OOPS sprry for the capitols. do u guys THINK I JUST NEED A NEW FAN? relocate radiator brackets? remove fan and add a electric? i dont understand why its not wanting to fit now | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | You need to use the old style pump and a water pump adapter. Water Pump Adapter | | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | it worked before with the same year 235, but this one scrapes one of the blades. Id rather not drill/tap my block. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Perhaps one blade is a little more bent? | | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | thats what im assuming. the radiator support isnt adjustable is it? weird thing i ran the motor for about 15 min the other day with the radiator in place and it wasent rubbing,
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Are all the motor mounts in good shape and bolts tightened? | | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | Weird thing I got a radiator from the guy I bought the engine from, and it's thinner then the radiator I had? The one with r11 a 53 d is thick and the 53 k is thinner and clears? How queer | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Can you post some pictures of the short pump and fan ? 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | Are you sure the water pump is good, no shaft play? | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I have a 55' 235 in my 53' and replaced the pump woth one from Patricks. I have a fan clearance problem too but solved it with a set of Morroso fan spacers and a fan from a 56' 265 engine. Never had any heating problems even on the hottest days. Check it out at the photos in the link below. | | | | | Joined: Sep 2008 Posts: 130 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 130 | Are you shure it was a 235. 53's had 216 engines in them. I had to set my radiator forward when I put my 235 in my 53. | | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | 53s had 261S? No , not this truck, its a 235. I got it to work buy adding a few shims under the radiator support. works fine now! | | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | My '53 half ton panel had a 235 in it, changed it out for a '60 261. No issues at all with the water pump or fan touching the rad. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Are you shure it was a 235. 53's had 216 engines in them. . . . 53s had 261S? No , not this truck, its a 235. What year 235 car/truck engine did you take out of your truck? What year 235 car/truck engine do you now have in your truck? sps's question about a 216 is appropriate, because only a 216 engine was originally available in a 1953 3100 truck. | | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | oops, i though sps said 261 came in 53's i misread. no it had a 56 235 in it and i sold that to a buddy and put another 235 in it. | | |
