0 members (),
83
Mod | | | Forums66 Topics128,081 Posts1,056,318 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 152 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 152 | I have a 49 with the battery under the floor, Does any one know what will stop the corrosion on the terminals? Thank you.
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I drive my '49 daily and once a month, I service the battery. Meaning, that I clean the terminals and check the water level.
I find that I have more corrosion in the winter, as of course I'm driving in the rain constantly, and the battery does get wet from spray, and from condensation.
Also, coating the terminals after assembly with dielectric grease, or vaseline helps. You can still end up with corrosion right on the posts though.
The next time I need a new battery I'll probably spring for an optima. So far though, I've been too cheap.
