| | | Forums66 Topics128,021 Posts1,055,346 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 23 New Guy | | New Guy Joined: Oct 2009 Posts: 23 | have the windlace installed...works great. Headlights will be better with the new bulbs, once I order them from the supplier mentioned earlier. Had a problem with headlights not working,...again. Solved with sourcing to a double fused light control switch. About the hubcaps.. I have an S-10 rear-end installed on my '37 truck. Works great. Used the 4-wheel drive option to gain a little better gas mileage. It is a 5 lug wheel, the old, '37 had a 6-lug wheel. The front wheels on the truck are still '37, 6-lug. The original hubcaps have clips on the wheels to retain the hubcaps. The new 5-lug wheels have nubs stamped into them to retain the caps. I cannot find duplicates to the original which will attach via the nubs instead of the clips. I have studied the original hubcaps and am wondering is anyone has tried to modify them to fit the nub type of wheel? It looks like a rolling of the inside lip would do the trick. I need to go from the 7 3/4" or so now on the original caps to the 7 5/8" or so of the new wheels. I can buy all new caps, but I really like the old ones. They have a black swoop on them vs the new ones with a blue swoop. I also imagine the old ones are a little heavier metal. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Wheelsmith will modify them so that you don't have to worry about losing a cap at speed. That's the route I'll be going. | | | | | Joined: Oct 2009 Posts: 23 New Guy | | New Guy Joined: Oct 2009 Posts: 23 | thank you for the reply. I will be contacting Wheelsmith.
| | | | | Joined: Oct 2009 Posts: 23 New Guy | | New Guy Joined: Oct 2009 Posts: 23 | I have sent several e-mails to Wheelsmith, called the 800 number. NO response either source. Have you talked to them?
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | No I haven't contacted them yet. I just got my hubcaps, and was planning on calling them within the next week. I'll let you know if I can get through. | | |
