1 members (baldeagle), 89 guests, and 4 robots.
Topics128,037
Posts1,055,466
Members48,424
#903782 12/15/2012 10:38 AM
Looking to convert my 1968 dually flatbed original wheel split rims w/tubes required, to a more modern tubeless type wheel. Can anyone tell me what other Chevy 1 ton truck years will fit my 68? My 8 lug wheels are 16 inch x I believe 6 inch. Need front and rear.
Jon D. #903791 12/15/2012 11:04 AM
You don't have to stay GM, all the 8 luggers are the same bolt pattern I think.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Jon D. #903799 12/15/2012 11:25 AM
Ok.Thank You. That really opens up the possibilities and ease of locating wheels
1968 C30 1 Ton
Jon D. #903809 12/15/2012 12:35 PM
BTW, Don't know about where you live but here there are tons of wheels and tires on Craigslist every day.
1953 Chevrolet 3600
Jon D. #904006 12/16/2012 4:27 PM
0
0 Offline
Well if your looking to sell your original wheels I'd be [email protected] Thanks...
Jon D. #904010 12/16/2012 4:48 PM
RE.. One Ton Wheels.
Wheels that weigh one ton each would not be easy to change!
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
Jon D. #904566 12/18/2012 9:24 PM
0
0 Offline
See my post under "driveline" unless someone can provide the info on replacement one piece wheels, guys with 67-70 one tons are stuck with the original wheels the truck came with when new...
Jon D. #904629 12/19/2012 8:38 AM
19.5" 8 lug dual wheels (tubeless) are available and I'm pretty sure they'll fit over your brakes.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Jon D. #904997 12/20/2012 12:03 PM
I converted my 71 GMC one ton to tubeless. Had to use a special GM plate between the new tapered lug nuts and wheel. Bought the plates at a junk yard and new nuts from Auto Supply. You will find the holes on most tubeless rims to be a sloppy fit on the original studs. The plate and tapered nuts takes care of that. You will also notice the studs are just a tad too short when everything is bolted on. Better check nut torque after fisrt 250 miles
Jon D. #905070 12/20/2012 5:39 PM
0
0 Offline
NCridgerunner..1971 is close enough to 1970....What wheels did you use, especially in the Front? I have later model wheels in the back outer - the inners are the original with the outer ring, as they are "Hub Centric" I tried to put the outer rears on the front & found they go to far in, against the control arms, never even got to the lug studs. What I have in the front are 16.5 from most likely a mid 70 ies 3/4 ton. Not "Hub Centric" the taper in the wheel is the strength from the lug nut.The guy who had the truck before me did all the wheel switching, I'm trying to get it back with Radial tubeless tires...I just need to know what wheels to use....Thanks
Jon D. #905232 12/21/2012 12:23 PM
The tubeless front wheels were already on my truck. I changed the back wheels becuase I needed new tires. The locking ring is so dangerous it cost big money to change the tires. I have no idea what truck my rear wheels came off of. The tire company had a used set and said "try them". They just happen to work fine even though the offset was slightly different. They did however look to be exactly the same offset as their 1974 1 ton truck they use to haul off old tires. Wish I could help more.
Jon D. #912164 01/16/2013 8:34 AM
Crusing in the Passing Lane
I installed 1976 16" Chevy one ton tubeless wheels on my 64 wrecker, no problem. The wheels are not coined , that's the biggest problem because coined wheels will not sit tight on the hub.
Currently cruising
in the Passing Lane
Rest in Peace
Moderated by  Dusty53
