12 members (Otto Skorzeny, dt235sd, mason86, Bill Hanlon, MickeyP, 68ironhead, Greg_H, tclederman, Shade Baby, 3B, Charles in CA, 32Fordpuchoptop), 98 guests, and 2 robots.
Topics128,049
Posts1,055,649
Working on a '50 3600. The window frame for the side glass has 4- 1/4" x 20 (maybe 28) attaching points that fasten the frame to the track inside the door. What are the correct fasteners? There isn't much room clearance wise and I can't find any vendor that lists the part. Any help would be appreciated.
This proud Veteran says there's nothin' like American Steel!
They are 1/4" NC standard. I bought machine screws at Home Depot that were slightly longer (1/2"). The original clutch heads are usually damaged in removal. I cut mine with a die grinder to match them for length.
