4 members (PAUL Berardi, Gray_Ghost, JW51, moparguy), 123 guests, and 2 robots.
Topics128,111
Posts1,056,244
Members48,437
I have a 53 chevy 3/4 ton with original split rims that are 8 lugs. Tire shop doesn't want to touch them for me. I would like any input on wheels I could replace these with. 15" or 16". I wish I could use my original hubcaps though! They look great and they match my overall color scheme. Any ideas would be great thanks
tru design wheels in denver co will take your rims apart and weld new ones to your original wheel hubs
it's pricy but you can keep your 8 lug wheels and use your hubcaps
pm me if you want the number
rolf
1963 c10
any other options like wheels off an older 3/4 ton that will allow use of my hubcaps?
There are numerous posts on this topic. I will share with you what I did because I retained my original hubcaps. The rears will bolt right up, I used wheels off a 1991 Chevrolet Suburban 3/4-ton. The fronts will not clear in most cases without work. I modified my steering arms and tie-rod ends for clearance. Search through some of the posts for other ideas. PM me if you want all the details on how to attach the hubcap clips and modify the front end pieces. Here is picture link you can see my caps/truck.
http://www.flickr.com/photos/advance-design_parts_co/8129054429/in/set-72157631867396207
Have you tried a "real" tire shop that does heavy trucks, equipment, etc? This shouldn't be a problem for them.
Ford 8 lug rims from the 70's up until about 97 work good. Dexter wheel has "trailer rims" that some members have used successfully. I used some 16" Fords, they just barely clear.
http://s1074.beta.photobucket.com/u...mp;_suid=1356102398016021678446910493304
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
thanks guys, that'll give me some ideas to toss around!
So i can just tack weld the hubcap clips on? Or maybe put some small bolts through the wheel to hold the hubcap clips on?
Hey matt, i did a lot of work on this and posted photos. If you search for harryr posts, the original post was no 748598. Let me know if i can help.
Harry
748598
