0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
Junior Member
Junior Member
i now have my ignition switch in my panel, after setting up for 28 years.......the key was lost.( been running wire from coil to battery)...now that is has been back on the road for 4 weeks......i had a guy make me a key for it, after re-installing the switch, on the 3 conections on back of switch, the old screws were wrapped with what looked lake black elect. tape....after i hooked up the wires do, i need to re-wrap wire connections with electrial tape??????nice to have gas gauge working with the new keyed switch........i left the witch hanging down from wires trying to find light bulb for the switch.no luck yet.......6 volt bulbs are hard to find.......thanks for all replies,,,,,
1950 Chevy Panel 310
flintriver,
Jim Carter, Chevy Duty, and American Classic Truck Parts (this forum's sponsor) should have the bulbs.
http://oldchevytrucks.biz/p/1947_1955/fullpage.php?page=068&session=1078332
http://www.americanclassic.com/asp/...;iyear=1950&ytype=to&exyear=1952
Covering the ignition connections is not required but it is not a bad idea. I bet almost everyone who has worked under the dash with the battery connected has gotten a spark from touching a loose wire to one of the hot leads on the rear of the ignition.
Tim
Junior Member
Junior Member
thanks......for the info......i think i will wrap the connections........and check chevyduty for bulbs.............thanks
