6 members (CATMAN, tclederman, BarryP, DadsFirstPickup, Bill Hanlon, Millenimech), 95 guests, and 4 robots.
Topics128,154
Posts1,056,842
Members48,456
Hello, can anyone tell me how to remove the rear brake shoes/pads from a 1940 Master Deluxe? See pictures of my brakes. I am replacing the brake lines, wheel cylinders, brake shoes, and springs, but can't figure out how to get the brake shoes/pads off. Please help
Brakes Pic1
Brakes Pic2
Brake Pic3
Brake Pic4
1946 Chevy Truck Export Blue with Black Trim
3B Offline
Hy mauricioaglr, there are pin retaining clips on the back side of the pins, you have to bend up the end of the clip which is not in the groove in the pin, bend it up just enough to allow the clip to be pushed back over the pin and out of the groove in the pin. If you're careful you should be able to reuse the clips on reassembly, hope that helps.
Those are Huck brakes. Here is a diagramn of the assembly. Brake Diagram You need to remove the clip, designated as 5.057 on the diagram. It is behind on the back end of the pin at the bottom. There is a wide area on the clip that you bend up and then you can slip the clip off the pin. The other two pins are fastened the same one. Be really careful with the clips because they are hard to find new.
1951 1 Ton Completed
You can get the shoe anchor clips from Chevs of the 40s. www.chevsofthe40s.com
1939 Chevrolet Stake Truck
Thank you for the information. I am going to try to take them off this weekend.
