8 members (68ironhead, jmoore, Joe H, Phak1, 55shaker, 3B, Waveski, 1 invisible),
74
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,154 Posts1,056,834 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | Hello, can anyone tell me how to remove the rear brake shoes/pads from a 1940 Master Deluxe? See pictures of my brakes. I am replacing the brake lines, wheel cylinders, brake shoes, and springs, but can't figure out how to get the brake shoes/pads off. Please help Brakes Pic1 Brakes Pic2 Brake Pic3 Brake Pic4
1946 Chevy Truck Export Blue with Black Trim
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy mauricioaglr, there are pin retaining clips on the back side of the pins, you have to bend up the end of the clip which is not in the groove in the pin, bend it up just enough to allow the clip to be pushed back over the pin and out of the groove in the pin. If you're careful you should be able to reuse the clips on reassembly, hope that helps. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Those are Huck brakes. Here is a diagramn of the assembly. Brake Diagram You need to remove the clip, designated as 5.057 on the diagram. It is behind on the back end of the pin at the bottom. There is a wide area on the clip that you bend up and then you can slip the clip off the pin. The other two pins are fastened the same one. Be really careful with the clips because they are hard to find new. | | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | You can get the shoe anchor clips from Chevs of the 40s. www.chevsofthe40s.com
1939 Chevrolet Stake Truck
| | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | Thank you for the information. I am going to try to take them off this weekend.
