1 members (Materman),
115
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | looks like a pump off of a early/mid 60's chevy.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Str8six, the reservoir on those pumps can be interchanged, that way you can find the one with the correct configuration of return line attachments. As "Tommy" said the pump looks like the ones used until the mid sixties, hope that helps. | | | | | Joined: Dec 2012 Posts: 7 New Guy | | New Guy Joined: Dec 2012 Posts: 7 | Thanks guys. I actually have a pump that came up in the local parts stores catalog as a 62 chevy pump, however it looks like the attached image on the back. Pump fits tight in the bracket pictured in the above links so the indent on the right lower portion around the attachment bolt does not allow it to pivot. I dont have the pump with the smooth back so nothing to interchange. I am wondering if anyone might have one with the same smooth case, if they do, possibly a casting number might lead me in the right direction. [IMG] http://i64.photobucket.com/albums/h168/lowrider62/pump/pump1_zps71191d6e.jpg[/IMG] | | | | | Joined: Dec 2012 Posts: 7 New Guy | | New Guy Joined: Dec 2012 Posts: 7 | After making some alterations to the bracket I have been able to get it to bolt up to the motor using the pump that I have. I would still be interested in knowing what pump is in those first pictures. | | |
