0 members (),
100
Mod | | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | I've been trying to get the rear tail shaft oil seal replaced in my 64' with the 230 and 3 on the tree, and when I took it out, it didn't come out nearly as clean as I was hoping for. My parts person can't find it in her books, and without a number to go by and the old seal in such bad shape, we can't size it for a new one. Does anyone happen to know the part number for the new seal? Appreciate any help with this. Tramp | | | | | Joined: Apr 2005 Posts: 2,101 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,101 | The seal number is 8850. It is common to 3 speeds, 3 speed OD's, TH350,& Powerglide. Fred
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Tramp, the standard duty three speed (four bolt side cover) o.e.m. p/n for the rear seal is 3871649 = Napa NOS15041, or National 9613S the heavy duty three speed (more than four bolt side cover) o.e.m. p/n for the seal is 3769588 = Napa NOS22340 or National 471341, hope that helps. | | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | I appreciate the shout on the part numbers. I gave my parts gal a call and she has several on the shelf so it looks like I need to get out today and get to town. Thanks again. | | |
