7 members (TUTS 59, Gray_Ghost, panic, tclederman, Peggy M, MRMEROTH11, Wickedbass),
122
0
Mod | | | Forums66 Topics128,068 Posts1,055,880 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 55 | hey guys,
i have a huge dilemma on my hands. All i have to do is put a new clutch in my 1958 235 and its DONE, but I can't seem to find a clutch that fits in my bellhousing like the original one i pulled out did. its 11" in diameter, i've got 3 DIFFERENT CLUTCHES AND THEY ALL DON'T FIT PROPERLY! The bolt patterns all match up perfectly, but the size of the pressure plate housing is larger in diameter than the old one, by about 3/4in. This is driving me nuts, i'm guessing i either don't have the original bellhousing, original flywheel, or the new clutches are just made larger. any input? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The bolt pattern of your pressure plate matches the flywheel?
The clutch disc does not fit under the presure plate?
Did you buy a complete clutch assembly, or just the clutch disc?
| | | | | Joined: Oct 2012 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 55 | ya the bolt patterns match, but the pressure plate is too large, it rubs up against the bellhousing. I bought three seperate whole kits, i.e. pressure plate in pressure plate housing, with clutch disc, throwout bearing, etc.
| | | | | Joined: Dec 2012 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2012 Posts: 97 | I you do have the old core in hand, better go fetch it till you figure this out. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | You say "in my 1958 235 ", but is this a 58 truck you are working on? I do not think you will get an 11" clutch to fit in most passenger car 6 cylinder bellhousing.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2012 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 69 | Try calling Clutch Exchange at 770-943-2666, these guys helped me out when I couldn't find parts for my '56....Maybe they can guide you in the right direction..They sure helped me..They're located in Pennsylvania and ship pretty fast..Good Luck..Terry | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | gbuck,
Are you referring to a passenger car clutch housing? Sorry, I missed guessing that possibility.
Are you putting the engine in a 1958 car or truck?
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | What is the casting number on your flywheel? Post here and we can find a clutch.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Jul 2012 Posts: 93 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2012 Posts: 93 | was the original a diaphram style pressure plate and the later one a borg & beck spring style? Usually an 11" diaphram (flat spring-not a bent finger spring) will fit within most any chevy housing. | | | | | Joined: Oct 2012 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 55 | the casting number is 3705410, its possible the "1" is a 7 it was really hard to read, but im 90% positive it's a "1". the fingers are flat-style, i don't know if that's from wear or how they are originally. It's just the outer housing of the pressure plate doesn't clear the inside of the bell-housing. its freaking frustrating. when you measure the difference between a new pressure plate housing/diaphram its 3/4in. larger than the one i pulled out. | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | The master parts book call out a 1955 flywheel. http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0147.htm Try going to your FLAPS and asking for a 11" clutch for a 261. Also, can you post a link show a photo of your bellhousing? Like others have said, you may have one for a car.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | gbuck,
Are you working with a car bellhousing or a truck bellhousing?
| | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | That's an interesting casting # 3705410.
Looking at the 57 MPC listed above, that casting is listed atleast 4 times, with 4 different part #'s.
Different size, 9 1/2, 10, 11.
Beginning with 54 Pass., Comm to 57 Pass., Comm.
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Oct 2012 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 55 | hey guys, no need to worry any more I found a clutch that fits. Out local "old time" shop in Watsonville, Townsends, helped me out. This guys Bill who knows these old motors like the back of his hand got me one that fits. I don't remember what he said exactly it was for but it works. thanks for all the input. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Why don't you share the part number for the parts you got, it may help someone else down the line in the same spot you were. | | | | | Joined: Oct 2012 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 55 | It's a CNT clutch kit, part number: 200.62042, costs about $160. includes pilot bushing, throwout bearing, clutch disk, pressure plate, alignment tool. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Oct 2012 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 55 | if you read my original post, 1958 235. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | If you click the link gbuck I think Tim is trying to show that part# is for a different year....
| | | | | Joined: Oct 2012 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 55 | if thats what it searches as, that must be what its for. It doesn't say on the box, I don't remember the parts shop telling me either. He just said that it should work. | | |
