| | | Forums66 Topics128,108 Posts1,056,238 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#90381 05/20/2005 9:17 AM | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | will this work my 1950 6 volt works good wondering if i could mount a 12 volt battery on the firewall and hook up an alternator to charge it for a 12 volt sound system leaving the rest of the truck 6 volt | | |
#90382 05/20/2005 12:10 PM | Joined: May 2005 Posts: 29 Junior Member | | Junior Member Joined: May 2005 Posts: 29 | I think you may end up buring out your 6volt lights, indicators, etc... I may be wrong. I think you may be able to leave the exisiting wire harness, but change out your lights, etc. Theres a great "how-to" in the tech section of this website. It discusses the 12 volt conversion and what should be done. And what should NOT be done.
Jason | | |
#90383 05/20/2005 1:34 PM | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | I think it would be much easier to change it to 12 volt period. Get your bulbs, resistor to gas gauge and a 12 volt alternator or generator. You'll love it. It will start much easier with 12 volts.
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#90384 05/21/2005 1:36 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Are you talking about running an alternator for the 12V and keeping the generator for the 6V system? That would work if you could figure how to mount it but probably un-necessary. If all you are running off the 12V battery is a stereo it will take a lot of running to run it down. Rig a power outlet for it and plug a trickle charger into it every night. As far as starting better on 12 V, if you have proper size cables and good proper grounds you will have no problems starting with 6V. | | |
#90385 05/21/2005 3:14 AM | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | What about adding another six volt battery? Batteries in series for the sound system and parallel for everything else. | | |
#90386 05/21/2005 4:55 AM | Joined: Oct 2003 Posts: 124 Member | | Member Joined: Oct 2003 Posts: 124 | I used a 6V to 12V converter and have a killer sound system in my 54. Two 2-channel amps, a signal processor, and front and rear speakers. It pulls less amps than the original radio.
Installed all under the seat and hid the speakers - so all look stock. | | |
#90387 05/21/2005 12:10 PM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | I think Fab 51 has the right idea;switching to 12 volts,and negative ground(which nobody brought up) will be more workable for a daily driver,not to mention being able to find accessories for your rig,being able to jump-start your wife's barge if it's battery goes dead,switch to HEi if you want to,and replacement parts for 12 volt are a fraction of the cost of 6 volt parts. Don't get me wrong-if it was my truck,I'd leave it 6 volt,and not worry about a stereo,but since you want to add the music box,you might as well do the full monty and just make it all 12 volt,with an internally regulated alternator. | | |
#90388 05/21/2005 6:51 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | It is possible to run dual electrical systems, but given the amount of trouble, I don't think I'd bother.
Once you've mounted the 12-volt alternator and installed a 12-volt battery, you're not far from a complete conversion to 12-volts.
You'll end up replacing all the bulbs, and installing some voltage reducing resisters, but its not a huge project, and will be easier to maintain than a dual system.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
