3 members (Lostbuthaulinass, Otto Skorzeny, Nick in Manitou), 81 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#898308 11/21/2012 1:25 PM
I just got a new axle for my bus. I found a great deal on a Dana 80 with disc brakes, 4.63 gears and came from a 2002 Chevy 3500HD truck with factory 19.5s on it. I had the guy measure the width of the outside to outside tires and it was about an inch wider than mine, although it could be just the difference in tire size. I'll have to get the measurements for WMS to WMS on it and compare to mine. I did measure the spring moubnts and oddly enough, or not, they are the same at 40.5". This is looking like a good swap so far. I'm probably going to wait until Spring to do the actual swap though and also do front spindle swaps for disc brakes like in Grigg's Tech Tip. Also change the transmission to a TH400. Lots of work to do. smile
1956 Chevy School Bus Superior Body
fclaridge #902391 12/09/2012 7:42 PM
Ok, not sure this is of interest, but the WMS to WMS of this "new" axle is 66 1/4". Looked over the axle and brakes a little and I must say I'm pretty pleased with it so far and those calipers are sweet! Very large sized.
fclaridge #903355 12/13/2012 4:17 PM
And here is a pic of the axle. Funny how goofy stuff like this gets me excited. LOL
[IMG]http://i107.photobucket.com/albums/...-229CE5888386-12160-00000E6F48176C94.jpg[/IMG]
fclaridge #903548 12/14/2012 1:02 PM
V
VEW Offline
V Offline
If I were closer to you, I would help you make the changes. Since I'm not, I will follow this mod. Looks/sounds like a must do for me too. Thanks for posting.
~ Victor
1957 3100 - moved on
fclaridge #903798 12/15/2012 11:22 AM
Great axle with a huge range of gear options. This will be a terrific thread to follow...just keep up the pix!
1946 1.5-Ton Chevy Shorty Bus
All my best --- Tango
