2 members (HelmutVonSchet, 1 invisible),
112
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,195 Posts1,057,371 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#90364 05/17/2005 6:05 PM | Joined: May 2005 Posts: 29 Junior Member | | Junior Member Joined: May 2005 Posts: 29 | Guys, after realizing that my charging system is KAPUT, I'm going to install a alternator. Does anybody have any reference photos for brackets. The 235 I have had a generator on it, now I am looking for some ideas on brakets for the alternator.
Jason | | |
#90365 05/17/2005 6:49 PM | Joined: Jul 2000 Posts: 583 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 583 | You can see some examples at Randy Rundle's website (he's the moderator here in the electrical bay). Fifth Avenue Parts Counter | | |
#90366 05/17/2005 8:22 PM | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | skiffman - i "poor boyed" mine after i saw how much they were wanting for the "store bought" kind. i took the original generator bracket at the bottom- scooted it over a little(to the front i think) drilled another hole in it and used it for the bottom bracket. i used an all thread with nuts and washers as the rod for the bottom. i took the top adjustment bracket (arm)and flattened it out - turned it upside down and it fit just right. i elongated the hole in it a little to give me a little adjustment room. not original but then neither is the alternator.
54 3100 w/62 235 "Yosemite Sam" Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
#90367 05/17/2005 8:28 PM | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | I used the original generator upper bracket, and the lower alternator bracket from a '70 250. I had to drill a new hole in the 250's bracket, but it worked quite nicely.
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#90368 05/17/2005 9:54 PM | Joined: May 2005 Posts: 29 Junior Member | | Junior Member Joined: May 2005 Posts: 29 | Guys,
After searching the shop here at work, I "configured" a sweet mounting system bracket deal. I used the bottom generator bracket on the motor for the bottom.I put a bolt through the entire bracket(front to rear). For the top or adjustment bracket, I used a bracket off a 366 chevy bigblock. Worked perfect. The bracket on top actually forms and is bent to the exhaust manifold. Hooked up the alternator and she is charging. 13.98 at the battery, 13.99 at the alternator. I want to thank all the guys who responded to my posts. She is working SWEET !!!!!!!
Jason Connellee | | |
