1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 172 | what is the correct rear axle for a 1948 , 6400, as the axle on the truck i,m buying appears to have been changed some years ago and as it is the truck doesn,t have a parking brake .. its a 6 stud rear yet the front is a 5 stud. also what would the maximum gross weight for a 6400 be in kilograms as i reqiure the gross weight to complete some paperwork ,
many thanks ,mike,
live or die do it with spanner in hand
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | A 48 model 6400 is usually rated at 16,000 lb gross weight, check the door tag. 7257 kilograms
Axle is usually GM, sometimes Rockwell, and 10 studs on a 7.25" bolt circle on the rear would be stock in any case.
| | | | | Joined: Oct 2011 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 172 | what should the front axle be its got a 5 stud which i thought was original. i cant check the I.D, plate as the truck is still 200+ miles away untill i get her home in the new year,,
i believe that it is ex,
texas independant oil refining co, and came of a gentleman somewhere in the nevada desert three or four years ago, i think it could have been something like a drill rig truck or pipe carrier,,,its only chassis and cab at the moment .
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Front axle should have 5 lugs also on a 7.25" bolt circle. | | | | | Joined: Oct 2011 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 172 | thanks grigg, it sounds like it has the correct front axle. could the rear axle have been a two speed ?
i,m told the truck is a 6400 but is there any distinguishing items other than the tag plate that i could / should look out for ..
| | | | | Joined: Oct 2011 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 172 | i,m now thinking that this truck has lost its two speed rear end for some unknown reason in the past so a couple of questions,
1, how can i find out what the original rear end was ? 2, how could i source one ? and if needs be get it shipped from the states to the uk,,?
| | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | Some GMC's had 6 stud wheels. In any case it appears yours has been changed. I will look at my 48 shop manual and see if there is anything in the numbers that would indicate two speed axle. | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | For 48 the axle serial number would be located on the top of the carrier housing. For two speed on top of differentail carrier towards the rear and right. ratio standard single speed 6.17. Two speed 6.13 and 8.10. School bus option could be either6.13 0r 5.43. I didn't see anything on how to dechipher the numbers to indicate how it was equipped, that may be covered in the owners manual. | | | | | Joined: Oct 2011 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 172 | right i managed to get a friend to go and check ,to see if he could read the ,tag, on the axle. turns out the ,tag, is good and clearly readable the following is what we now know. ROCKWELL TBBO 0005A model F106 NXI ser no, 058315 ratio 6.2:1 so the question now is where / what has this axle come from and how old is it. i,v got some old books etc but nothing with this in.. also got the VIN no ,20RWH2292 thanks for all the help so far .. mike,,
| | | | | Joined: Oct 2011 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 172 | can any one identify what this rear axle is from and what year it is i,v been looking on the net and come up blank.
| | | | | Joined: Oct 2011 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 172 | i need to know what sort of parking brake it should have,, i suspect its of a truck with a trans brake,,
