1 members (Shade Baby),
21
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2002 Posts: 141 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 141 | Hey all, on my 52 AD the pedal that I push to start my truck does not engage when I press down on it. I always have do raise the pedal in various positions in order to get it to start. is there an adjustment to where I can fix this .I see a u shaped clip on the rod that engages the starter is that by chance the adjustment?or is there someplace else that I'm not seeing here. one day when the rich uncle decides to leave me all that money I can afford a manual. thanks for reding to all who does | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I think you probably need a new switch. Does it spin and make noise when you are moving it around, or only when you get it to the right spot? The linkage consists of two parts, the part that slides the gear on the starter in and out and the switch that contacts the lever to spin the starter.
#9033 10/25/2002 10:00 PM | Joined: Aug 2002 Posts: 141 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 141 | 4onthefloor starts good when you hit the right spot I really dont think it's the starter it's self but I've been wrong b4 I'll get someone to try and start it while I have a look see thanks | | |
#9034 10/25/2002 11:16 PM | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | Im geussing josiah is corect.To test his theory simply remove the switch on top of the starter and turn the contact around and replace it.If that works your good to go untill that side wears down and then it will need to be replaced.
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Another way to check is to use a prybar to move the lever on top of the starter and see if that works. If it does, you have linkage problems.
Fred 52 3600 69 C-10
| | | | | Joined: Aug 2002 Posts: 141 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 141 | Thanks FredT will try what you suggested today wheather getting a little cool here need to adjust,repair whatever is gonna be done b4 too much longer or I'll be laying in snow or waiting till spring. | | | | | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | A sagging or rusted cab can change position , and not allow the pedal to fully engage.I had that problem with a 49 GMC.Or it may be what the guys above suggest. | | |
#9038 10/29/2002 12:14 AM | Joined: Jan 2001 Posts: 230 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 230 | Is the return spring still on the linkage ? I see where you said " have to lift up on it " there should be a fairly robust spring to return the pedal when released , it's a coil typ retraction spring .
When you remove the starter switch to rotate the contact , also be sure to polish both contacts untill shiny .
-Nate There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
| | | | | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | Tony is dead on from my experience. Cab mounts are probably shot and have misaligned the starter rod. Any problems with brake and clutch pedals binding on the shafts? | | |
