| | | Forums66 Topics128,020 Posts1,055,345 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 60 | On my 46 1/2 ton one shock is missing . Any suggestions for a source of replacements .Or is there a good way to mount modern shocks with the stock axle ?
Allan 1946 GMC 1949 Mercury M68
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Try a Want Ad in the Swap Meet.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Any suggestions for a source of replacements. ebay, Apple, or Five Points. Or is there a good way to mount modern shocks with the stock axle ? Yes. You can fab shock mounts and/or I believe one or more of the vendors sells conversion kits (Jim Carter??) I converted my '38 coupe to tube shocks in the front using '39 straight axle mounts.
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Hey neighbor...I know a few local hoarders (myself included) that should be able to hook you up with a knee action replacement or you could investigate converting your truck to tube type shocks and scavenge some mounts off a local 51-53 frame. PM me if you need.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Links look under Parts. -W | | |
