0 members (),
144
8
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 96 Shop Shark | | Shop Shark Joined: May 2005 Posts: 96 | Hi,
How can I hook up my stock gauge-cluster to a T5 gearbox with mechanical speedo-drive.
Other words, who's selling those cables.
Jan | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | I went to a NAPA store and picked out one that would fit, a few inches too long but you can't see it anyway. I don't remember the part no.
I just noticed you are in Belgium. Don't know if you have a NAPA but their parts listings include the length and the buyers guide tab will tell which vehicles it fits. Maybe someone else will know if the end fittings are the same on later model Chevy trucks.
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | The cable that I had on my 37 pickup with the stock transmission and the stock speedometer fit right onto the speedometer hook up on the T-5 I bought for my truck. The ratio was slightly off so I bought an adapter to slow it down slightly. I found the adapter on ebaY.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | go to either D&D Speedometer (twin cities) or the speedometer shop (Milwaukee) and order a custom cable (they are dirt cheep). they also custom make adapters if you dont want to change the speedo drive gears correctly (to match your final drive)
| | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | I looked up my receipt. I used a NAPA part no. BK6151606. The stock one on my 4-speed was too short to reach the back of the T-5. BK6151606 fits a large number of vehicles including 60-72 Chevy trucks.
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | How can I hook up my stock gauge-cluster to a T5 gearbox with mechanical speedo-drive. Jan, What modifications did it take to install the T5? Thanks, Harold
Harold Is a restoration ever finished? | | | | | Joined: May 2005 Posts: 96 Shop Shark | | Shop Shark Joined: May 2005 Posts: 96 | thanks,a great help, I will check NAPA.
This is indeed a great forum !
Greetings from Belgium.
Ps: its a T5 behind a 350 chevy. on a 1942 PU | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | How can I hook up my stock gauge-cluster to a T5 gearbox with mechanical speedo-drive. Jan, What modifications did it take to install the T5? Thanks, Harold It depends on what year the truck is and the engine in the truck.
